Results 1 to 5 of 5
Thread: Each pass different than the previous
    Aug 2008
    Hey all, Got a simple question. Wen doing pocketing my pass rate is at .06 in and it takes 4 passes for a .25 in. The problem is that when all the passes are finished they dont line up giving the look of a stair case. What do I need to do to adjust this problem? Thanks for your input
    Apr 2006
    Can you post the g-code??? Thinking we can solve your problem if you let us peek.
    Feb 2006
    also check the rigidity of the spindle and bit
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Apr 2008
    canada
    I had the same issue with my semi-new built machine I'm still trying to figure out. The 1st time I was missing steps, my motors weren't tuned yet. I had to lower the speed of my machine to correct that. Most likely that's your issue too. The 2nd time one of my worm-gear screw got loose (at the coupler holding the motor and screw together), so when it got tense enough near the end motors kept spinning but the screw didn't. This made my gantry move back to a certain distance then stop instead of continuing to move back to the accurate location.
    Registered ImanCarrot's Avatar
    Nov 2005
    UK
    Climb Milling vs Conventional Milling?
    Your tool will deflect one way going from left to right (for example) and the other way comming back.
    Try unidirectional milling instead of bidirectional?
    I love deadlines- I like the whooshing sound they make as they fly by.
    1. Need Help!- cut depth per pass
      By christ371 in forum Dolphin CADCAM
      Last Post: 07-19-2008, 10:14 PM
    2. g code for repeat the previous move
      By woffler in forum G-Code Programing
      Last Post: 03-26-2008, 11:07 PM
    3. Heidenhain pass
      By inioxos in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 12-09-2007, 01:00 PM
    4. Can I run axes at different ipm on the same pass?
      By yorttroy in forum DIY CNC Router Table Machines
      Last Post: 01-04-2006, 01:34 PM
    5. the finishing pass
      By inthedark in forum General Metal Working Machines
      Last Post: 02-16-2004, 06:58 PM
