Results 1 to 6 of 6
Thread: My new machine
    Apr 2003
    My new machine
    Almost got my new machine completed.....
    The box off to the side is my home built (and designed) controller - bipolar chopper running at 40V. For the full story take a look at
    http://www.gloomy-place.com/cnc.htm
    Andy
    Registered WOODKNACK's Avatar
    Mar 2003
    Maine
    Hey,
    Looks good pal. I like your bearing design. What is the cutting area of that?
    My little piece of the web!
    http://users.adelphia.net/~wjdupont
    Apr 2003
    The cutting area is kind of interesting. This is a place I'm trying something new. I don't really have a lot of space and I also have two main jobs I want to use the machine for:
    1. Routing prototype PCBs
    2. CNC milling of parts in plastic and balsa
    So I've built the machine so that the table overhangs the sleds on which the bearings are mounted. This gives a nice rigid area in the centre of the table (actually offset to one end), that is about 6" by 10" for PCB milling. In addition I have a bigger area of approx 10" x 10" which is not so well supported but which I hope will be OK for lighter work.....
    I've already seen a few things that I may change, but for now I'll go with what I've got and see how it works out....
    Andy
    Registered abasir's Avatar
    Apr 2003
    Malaysia
    Hi Andy,
    Machine looks good! If you don't mind, could you provide some more pictures of the roller bearing mounting as it look easy to do with regular hand tools.
    You PCB also look good. What do you use a the milling bit?
    Thanks.
    Stupid questions make me smarter...
    See how smart I've become at www.9w2bsr.com ;-P
    Registered Jmtwo's Avatar
    Jun 2003
    Gilbert, AZ
    Talking
    Very Nice solution to the Y-Axis using the roller bearings. I had some Frakenstein idea going, but yours is much more elegant. I put together a little drawing of what I think you did to assemble. With the bearing angle rotated at a 45 and then bolted through to the mdf. Is this your approach?
    Apr 2003
    Yep that's exactly how I have things setup on my machine. SO far it seems to work well. One thing to watch out for is that the 45 degree bearings but an odd force on the rails when you apply twisting force to the (in my case) Z axis. The setup tries to force the rails apart, if the rails are not very stiff you can get a lot of movement........
    Andy
    1. CNC Glossary
      By CNCadmin in forum CNCzone Club House
      Last Post: 03-09-2008, 04:08 PM
    2. My First CNC Machine, Mr. Chips
      By Mr.Chips in forum DIY CNC Router Table Machines
      Last Post: 02-10-2007, 10:04 AM
    3. Confused about CNC software
      By samualt in forum General CAM Discussion
      Last Post: 06-30-2005, 09:18 PM
    4. Heads Up - Article about building CNC Milling Machine
      By samualt in forum CNCzone Club House
      Last Post: 06-13-2005, 03:43 PM
    5. FeatureCAM Expands Product Offering with Machine Simulation
      By CNCadmin in forum Product and Manufacturer Announcements
      Last Post: 01-21-2005, 07:58 PM
