Results 1 to 4 of 4
Thread: copper pipe rails
    Jan 2004
    NEW HAMPSHIRE
    copper pipe rails
    I have a question. What if one was to use 1" dia. copper tubing for linear rails? Furthermore, then fill them with compressed air, would this add any strength to them. I'm curious any speculation on that?.
    Gold Member
    Apr 2003
    Ohio, USA
    SPEEDRE I love ideas, copper tubbing really works well for pluming, some decorative things and........... well, I guess that's about it.
    Black pipe is much stronger and probably cheaper as well.
    Aug 2003
    No Added Strenght Is Added To The Tubing.
    If Anything Filled With Cement ????
    Besides Copper Is A Softmetal,not Very Good For Dirt Resistance As Dirt And Debrie Can Bite Into The Surface Causing A Lot Of Problems
    JEFFY
    May 2003
    UK
    I think the main problem would be a lack of surface hardness, then would become worn very quickly. As steel is cheaper it makes more sense.
    Compressed air is a nice idea but I think it would need to be at very high pressure to have any effect and even then I am not too sure it would help.
    Graham
  1. Gas Pipe Alternative?
    By JavaDog in forum DIY CNC Router Table Machines
    Last Post: 01-07-2011, 11:24 AM
  2. Add a second set of rails to X axis..need advice.
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 05-31-2005, 08:11 PM
  3. Support For Gas Pipe Rails
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 02-17-2004, 09:12 AM
  4. EMT conduit and copper?
    By davesaudio in forum DIY CNC Router Table Machines
    Last Post: 01-09-2004, 11:40 PM
  5. Pouring Silver insert into copper hole
    By NeoMoses in forum Casting Metals
    Last Post: 10-15-2003, 04:26 PM
