Results 1 to 3 of 3
Thread: Sharpen router bits or buy new ones?
    Feb 2008
    Can I sharpen router bits or buy new ones? Today, I found out that the tip of a 1/4" diameter straight plunge router bit is covered in black.
    Mar 2003
    Shelby Twp, MI....USA
    That's from too much heat. First thing you should do, is buy some bit cleaner and clean the bits after each use. They'll stay sharp longer.
    I wouldn't try sharpening them yourself, but you can get them sharpened. It's not cheap to get spiral bits sharpened (25-50% of the price of new ones) , but carbide tipped bits can be sharpened for usually less than $5. Keep in mind that after sharpening, the diameter will be slightly smaller.
    Aug 2006
    canada
    You can also lightly hone your bits with 600 & 1200 grit diamond honing stones in between grindings that will help them stay sharp for a bit longer, but you can only do that on the flat side of the bit and not the curve side and do equal honing on each cutting edge and only do a few strokes as diamond files cut fast. You can not do this on spiral bits.
    You can also use oven cleaner or lacquer thinner to clean your bits if you have no bit cleaner. Graham
  1. CNC router Bits
    By marksnwv in forum CNC Tooling
    Last Post: 11-18-2006, 11:48 AM
  2. How to sharpen Dowel Drill Bits - Brad Point
    By bignimmer in forum General Metalwork Discussion
    Last Post: 11-01-2006, 05:48 PM
  3. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 04:33 PM
  4. Router Bits in OZ
    By Exelanoz in forum Australia, New Zealand Club house
    Last Post: 11-17-2005, 09:41 PM
  5. CNC Router bits?
    By GalaticDan in forum Commercial CNC Wood Routers
    Last Post: 07-31-2005, 09:51 AM
