You need to be more specific as to what exactly you want to do. There are literally hundreds of bits that will cut MDF.![]()
I'm building a cnc router table (my first one!) to cut MDF wood, but I need to know which bit(s) to buy. The router that I have is a Bosch RA1161. Any suggestions/tips/ideas would be appreciated. Thanks!
each bit does different things/cuts/effects, all depends on what you want to do
