Results 1 to 3 of 3
Thread: How to attach lead screw
    Wanna be
    Mar 2004
    I am using 1/4" - 20 threaded rod for my lead screws on all 3 axis and am trying to figure out how to mount the ends. The thought that I have is just to use a simple flanged bearing on each end and a nut to hold it in place. Is this the correct way or is there a better way?
    Does anyone have a closeup pic of how they did theirs?
    Check out what I am working on at www.routerbitz.com!
    Mar 2004
    Spain
    The pinture below is not mine, is from other thread at the zone, I've stored at my HD as a help for the future. I do not remember the autor so I cannot direct you to the thread.
    Hope it helps
    Attached Thumbnails Attached Thumbnails How to attach lead screw-capturebearing.jpg
    Registered vladdy's Avatar
    Feb 2004
    Perogie Flats, Canada
    for that size / type of driver rod, I assume this will be a lighter use hobby machine, so a smaller bearing in a pillow block will be more than adequate, preferably at the drive end..
    If it's only a 'mini' type of 12 to 18" length, you may not even need any additional support, the example here has none, just a good quality air hose piece used as a flexible coupler, and locked with crimp clamps.. it's also 1/4 by 20tpi threaded rod, and MDF construction. Backlash seems to vary a bit, [go figure], but normally runs 0.004 to 0.006 ..The driven nut has no zero lash [or backlash] adjustment, it's just a 3/4" long coupler nut solder to piece of flat steel, and screwed to the x/y/z tables...
    Attached Thumbnails Attached Thumbnails How to attach lead screw-im000192.jpg
  1. Lead screw whip
    By spalm in forum DIY CNC Router Table Machines
    Last Post: 05-24-2005, 03:04 PM
  2. One lead screw off-centered..Will it work?
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 04-02-2005, 09:57 AM
  3. Alternate Lead Screw Mounting Idea
    By Jay C in forum Mechanical Calculations/Engineering Design
    Last Post: 02-20-2005, 02:32 PM
  4. How to machine a 56 Rockwell lead screw
    By bgolash in forum General Metalwork Discussion
    Last Post: 12-05-2004, 04:25 AM
  5. Ball Screw or Lead Screw? Which is Better?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 07-28-2004, 09:49 AM
