Hi
I am a joiner based in Southampton, UK. I've spent a fair bit of time over the last couple of months reading about DIY
CNC, and I have to say that I'm hooked!
I'm not quite sure what specific applications I have in mind for a
CNC router but I have a couple of things in mind (custom radiator cabinet grills, corian cutouts, mould/former construction, to name a few) but mostly machining and cutting 18mm MDF.
I intend to make a very cheap machine, but one which is capable of reasonably accurate/repeatable work and will be useful for creating
CNC#2.
My build will be based loosely on the
www.buildyourcnc.com model with improvements where I feel necessary. Mainly in the construction, as I said, I am a joiner!
Before I get too carried away, I want to check what I am doing is along the right lines.
Firstly, transmission, I intend on using 10mm threaded rod which has a pitch of 1.5mm. Is this suitable? I am hoping that this will be stable over greater distances, (approx table size of 800mm x 1400mm).
Secondly, drivers and motors. I have found
these kits and plan on using kit 1. At the moment I am struggling to get my head round the electronics side of things, will these have enough power to move my router around? Also, what else will I need on the electronics side of things to get this thing moving (with the exception of a PC and software)?
Thirdly, the router. I am luck in that I have several routers available to me from a trend T3 upto a 2200w festool. Is there a recommended router size given that I want to be able to machine 18mm mdf and might progress to aluminium.
Fourthly, speed and depth of cut. Just out of interest, what sort of cutting capacity should I expect from the machine that I have described above? If I wanted to cut out a square of 18mm mdf, 300mmx300mm how long will it take? what sort of depth of cut will it achieve? Could it cut the full 18mm in one hit?
I probably have about a million other questions but that will do for now!!
Thanks in advance
Stu.
