Results 1 to 4 of 4
Thread: New Machine Just Completed
    Mar 2004
    I've been working on this thing for over a year. Haven't checked it for .001 accuracy yet, but it seems to be very accurate - using a good square and the old eyeball. Everything can and needs to be adjusted to .001 or better but little things I've cut all check out square and VERY flat!! I'm using 2 4-axis HOBBYCNC boards driven through a CNC4PC board from Mach 3. This setup lets me use two 305 oz-in motors on the "X" to keep the gantry from racking without resorting to slaving axes together. It's got a full compliment of home and limit switches, runs 120 ipm and, so far, it's smooth as silk. The extra driver channels are going to run A and B axis drives when I get them built. Being an old airplane electrician, I'm a little possessed about wiring being neat. The control wiring is almost all hidden inside the frame and I'm working on getting the lower wiring under control. The router, vac and lighting (under the router mount) are all controlled by Mach's spindle control using relays. Working pretty good so far!!
    Registered teamtexas's Avatar
    Aug 2007
    Wow, nice job! And might I add you've got a nice looking shop there too. Pictures hanging on the walls?? You kicked the TV out of the living room and took it over didn't you?
    Dan
    Registered tauntdesigns's Avatar
    Nov 2005
    I'm jealous, Nicely done!
    Jack
    Walking is highly over-rated
    Apr 2008
    Looks awesome! Thanks for sharing the pics!
    Check out my projects at www.backyardworkshop.com
  1. Newbie- Build completed
    By GoFaster in forum Joes CNC Model 2006
    Last Post: 03-07-2008, 09:56 PM
  2. Newbie says - I have completed my Y-Axis! - Or have I??
    By WannaMakeStuff in forum DIY CNC Router Table Machines
    Last Post: 12-11-2007, 07:25 AM
  3. X2 completed for now maybe
    By hoss2006 in forum Benchtop Machines
    Last Post: 01-14-2007, 08:23 AM
  4. it's completed
    By pyroracing85 in forum General Metal Working Machines
    Last Post: 01-09-2005, 06:28 PM
  5. RFQ - Completed - thanks to all interested
    By kdoney in forum Employment Opportunity
    Last Post: 08-24-2004, 08:25 AM
