its called a gantry machine. I would get a different spindle the run out on the dremel is crazy, especially if you are making heavy cuts, i would use a porter cable 890 series router or similar. there is a Hitachi model that a lot of people have had success with as well and if memory serves me it less than the porter cable router.
which cad program are you using?
LinkBack URL
About LinkBacks
