Results 1 to 6 of 6
Thread: newbe question
    Jun 2004
    newbe question
    i am using wincnc by microsystems will it do 3d are do i need to find another
    program to use i left emails to the company nobody ever responded
    thanks jimmy
    Apr 2004
    looking at http://www.minitech.com/software/win...ncnc_index.htm
    says :"Supports up to 6 axis of simultaneous motion at 50khz."
    so it should
    by the way just make sure you know thats only the controller. you still have to find a "g-code" program to tell the controller what to do. somthing like "visualmill"
    also if you havnt already payed for this. might check out mach2 as its 1/6 the price .
    Apr 2004
    by the way is anyone really supporting this program anymore? could only find it on two sites and both were full of dead links/picture and i couldnt even get the demo
    kind of wanted to try it out compare it to other controllers
    Sep 2004
    Mach2 is about 1/6 the price but only about 1/1000 the quality. If your serious about your work, there is no substitute for WinCnc.
    Sep 2004
    Apr 2004
    THank you cncshop
    1. Extremely basic machining question.
      By touser in forum General Metalwork Discussion
      Last Post: 06-19-2005, 01:51 AM
    2. Question about power supplies
      By dowling177 in forum General Electronics Discussion
      Last Post: 01-28-2005, 08:01 AM
    3. Hobbycnc controler question
      By chas in forum Hobbycnc (Products)
      Last Post: 09-09-2004, 06:00 PM
    4. Just a question about plunge milling.
      By Machine1 in forum Hard and High Speed Machining
      Last Post: 01-28-2004, 09:36 PM
    5. HF lathe question
      By rs1300 in forum General Metal Working Machines
      Last Post: 01-19-2004, 12:22 PM
