Results 1 to 7 of 7
Thread: 24x24 "square" router build
    Apr 2008
    canada
    Finally have enough build to start a thread. I got my plans from Rockcliff. Not really a step-by-step instructions by any means... But after some time looking at it I was able to figure out which direction to go with. I have some fancy ideas, but for now sticking with the basics and just be familiar with the basics before trying out new things.
    My CNC plan is a 24" X axis, 24" Y axis, and a 7" Z axis; flying gantry with a semi-open table. Semi-open for added stiffness, since not the entire table can be touched with the tool anyways so might was well put "supports" on those areas. Cutting area roughly 16" x 16.5" x 7" (capable to cut 3" below the ground level). 4 motors 269oz Xylotex stepper motors total (2 motors for the X axis). Main projects would be wood, maybe try out a little plastic and carbon fiber in the future?? Also have a new Hitach 2 1/4 router everyone's talking about for the spindle, love it so far!!
    I'm planning on putting hinges in the middle of the Y axis side supports so it can fold parallel with the X axis. This way it can be "folded" to save a little space during transportation/storage.
    Unfortunately my new Xyoltex board got damaged a few days ago. So waiting to here back to see if it can be repaired. If it can't be repaired I was going to order a new board from them again, but I haven't heard from them in 1/2 a week so going to order from elsewhere. I usually get fast email before I bought their kit...
    I have a simple solution to get a 4th axis (tilting Z axis) made cheaply and sturdy using a similar linear bearing setup as I'm currently using. I think it's very doable and very DIY friendly, but won't be messing with that till later later.
    Anyways here's what I have so far: Y + Z axis Not much to look at yet. Comments/suggestions welcome!
    Thanks,
    Nick
    Apr 2007
    If it is a blown driver chip they will send you another board and then repair your original board and send it to someone who also needs a replacement board. You don't normally get your original board back. It cost me about $70usd when it happened to mine last year. Read the repair/replacement policy on their website for more details.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Apr 2008
    canada
    it's one of the tiny resistors(?) that blew, shown in the pict:
    http://www.runtrod.com/files/1.jpg
    That part glows like an LED for a second. I asked if it can be replaced, repaired or whatever. I understand that it may not be covered so that's why I asked them if it can be repaired... at least say they can't do anything so I know I should buy a new one right away instead of waiting around. Oh well, can't wait much longer on them so just buying from elsewhere this time...
    Apr 2008
    canada
    finished the Z axis.
    Also ordered a new 5 axis control board, might as well get a spare axis for potential future upgrade
    Registered acondit's Avatar
    Apr 2005
    Quote Originally Posted by nicanor76 View Post
    That part in the picture actually looks like it is a surface mount LED.
    Alan
    Apr 2008
    canada
    ahh, I think you're right. It's so small, I thought it was a burnt out chip that got discolored. So if that part isn't fried, why would it just power on for 1/4 second then flick off right away. Either way it still doesn't answer why Xyoltex never responded to me email...
    Apr 2005
    I don't know maybe your documentation for the board will give you a clue what kind of indicator it is supposed to be.
    Alan
    1. Newbie - To build or not to build Router/Plasma Table
      By dfranks in forum General Waterjet
      Last Post: 04-08-2011, 12:16 AM
    2. My New 24x24 V-Groove Router Design Log
      By widgitmaster in forum CNC Wood Router Project Log
      Last Post: 11-04-2010, 03:26 PM
    3. Router Using 3/4" MDF (first router build)
      By eguy208 in forum CNC Wood Router Project Log
      Last Post: 04-11-2008, 11:33 AM
    4. Build a CNC Router - FAQ
      By samualt in forum DIY CNC Router Table Machines
      Last Post: 04-13-2004, 09:55 AM
