Results 1 to 3 of 3
Thread: coupling a worm to the stepper motor
    May 2008
    andorra
    The problem is that the worm and the stepper motor have different radius, is there any hack/simple solution?
    Thanks in advance, I'm totally blocked because of this issue, the rest is all easy :-)
    Gir
    Gir is offline
    May 2006
    bore one side of the coupler larger or use jaw type couplers which can mix and match the proper diameters.
    May 2008
    andorra
    Quote Originally Posted by Gir View Post
    I googled it and it sounds like the perfect solution, there are not many on ebay unfortunately..
    What is your preferred shop for buying them?
    Thanks!
  1. How can I coupling a stepper motor axis directly to other axis?
    By meknik2001 in forum Stepper Motors and Drives
    Last Post: 05-08-2008, 02:54 PM
  2. Coupling stepper to ball screw
    By garagefela in forum Linear and Rotary Motion
    Last Post: 08-18-2006, 06:51 PM
  3. Can we help Ito (Stepper screw coupling issues)
    By ynneb in forum Linear and Rotary Motion
    Last Post: 11-25-2005, 12:31 PM
  4. stepper coupling
    By Maximebleu in forum Mechanical Calculations/Engineering Design
    Last Post: 05-14-2005, 03:24 AM
