Results 1 to 2 of 2
Thread: Linear rod+max length?
    Jun 2004
    Hello guys-
    I have a question regarding linear rod, does that ever "bow/flex" at some point if its to long? I am looking to make the x 96 in. I would also guess it would depend on the weight of a gantry...
    Logic dictates that its all depends on the material.. I was looking at the mcmastercarr website, as well as the posts in this forum.. but could not find anything specifically regarding length restrictions.
    Any info/recommendations would be appreciated...
    J
    Aug 2004
    Depends more on the diameter of the rod, I used 2 5/8 rods for a 36 in axis and there is too much flex in it. For 96 inches you would need to have at least 3 in diameter if not more. I have a 7 ' 8" ball screw that is 1.5" roundd and it hsa some flex in it. Hope that this helps a little.
  1. Max length of linear rod?
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 03-05-2005, 09:47 PM
  2. Drill Rod For Linear Ways
    By heilcnc in forum General Metal Working Machines
    Last Post: 02-28-2005, 12:41 PM
  3. Thomson vs. ground drill rod
    By TommyB in forum DIY CNC Router Table Machines
    Last Post: 03-21-2004, 11:08 AM
  4. what acme tap do I need for the Enco ACME rod?
    By AJ_Mac2001 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2004, 08:24 AM
  5. Linear rails, rod which is better for cnc?
    By snokid in forum DIY CNC Router Table Machines
    Last Post: 12-29-2003, 08:12 PM
