Results 1 to 4 of 4
Thread: Do i need a Vacuum Hold System
    Apr 2008
    Puerto Rico
    Hi
    I'm new in the router world and I'm planning on buying a 4' x 8' router table and I would like to know If I need a vacuum system or not, I own a sign shop and most of the work I will be using the router for is cutting acrilic, pvc, aluminum etc. I was thinking in using a 1/4 pvc under the pice I'm goint to cut so i wll not damage the table bed, so I do not know if the vacuum will work for me or not or there is other way on doing this.
    RCS
    May 2006
    Usually spoilboards are MDF, cheap and its a porous material. If you use a vacuum pump it will hold the pvc down but not the material you're cutting. Buying a system is really up to you; preference because you have to decide if it will earn you the extra money. If you do a lot of thin sheet goods yes its probably worth it but I and my others find that leaving tabs or onion skins works fine and to just screw or clamp down the work piece.
    Registered GWEIKE-LASER's Avatar
    Apr 2008
    CHINA
    Smile vacum table is better for wood engraving
    even without vacuum table, the CNC router will equipe with the special clamp to fix the processing project. So the vacuum table is up your choice.
    Usually we put LDF under the processing project to protect the vacuum table when do cutting. Then you will avoid to cut the seal and will not lose the function of suction of vacumm table. See our machine clamp
    Attached Thumbnails Attached Thumbnails Do i need a Vacuum Hold System-wk1212-3.jpg
    Jan 2006
    New Zealand
    You can also use pressure plates that mount on the spindle, they stop the sheet from lifting even when you do use a vacuum pump.
    RemainCNC NZ Excitech 1530 router.
    Shannon.
  1. hold down vacuum system
    By alfonsonog in forum DIY CNC Router Table Machines
    Last Post: 02-10-2008, 02:11 PM
  2. All acrylic gate valve for the vacuum hold down
    By the_paco in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 03:50 PM
  3. Vacuum Hold down for wood.
    By HomeCNC in forum DIY CNC Router Table Machines
    Last Post: 07-24-2007, 12:16 AM
  4. 4x8 Vacuum Hold Down
    By elogicca in forum DIY CNC Router Table Machines
    Last Post: 07-23-2007, 09:06 PM
  5. Vacuum system to hold down paper
    By Aan in forum Open Source CNC Machine Designs
    Last Post: 04-06-2006, 11:13 AM
