Simple right angle brackets work well enough for the smaller machines but you can get as elaborate as you want to with any size machine. You can drill and tap the delrin AB nuts for screws or use through-holes. Make the bracket that the AB nuts are mounted on adjustable by putting slotted holes where they have mounting screws.
CarveOne
LinkBack URL
About LinkBacks
