Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Thread: Gecko Drives worth the cost?
    Jun 2007
    Thinking about purchasing Gecko drives for my build.
    What is the big hubub about them? Why are they so much better than others? That seems to be the general opinion. I have read that they can increase inch times and power on most machines, etc. What gives them this ability?
    I can get a 4 axis xylotex system (plug and play for 475)...
    Why pay 417 for 3 gecko drives, no motors and no controller?
    Is it worth it?
    Thanks for your time.
    GB
    Jan 2005
    The controller is your computer. If you go for the G203Vs you have idiot proof drives. Unkillable!
    I bought, paid for and built four other four axis drives and watched them smoke for one reason or another one at a time.
    I've bought 5 (one for a spare) G203Vs and had to send one back for adjustment. (no cost other than shipping)
    You get what you pay for with Gecko. Quality equipment (the kind of quality that flies on the shuttle) at a bargain price. We are his proving ground and industry the bread and butter.
    Let me hasten to say that I don't nor never have I ever, worked for Gecko or any other electronics firm. I'm just an old retired dumb cluck user up in Bakersfield, Ca. poking about in my favorite hobby. ......and I am one HUGE Gecko 203V fan!
    Him what has ears, let him hear!
    “ In questions of power, let no more be heard of confidence in man, but bind him down from mischief by the chains of the Constitution.” Thomas Jefferson
    Jan 2007
    A lot of it is voltage. Xylotex run only 2 amps, which is serviceable if a bit low, but they only run at 24 volts. This really kills any motor performance over a few IPM. Xylotex can be a fine budget option for small mills, but especially with a router they are bad news for rapids and fast cutting.
    Geckos are good to something like 80 volts. They also handle up to 7 amps or so if I remember correctly. Nice if you need the extra power, but even if you are only running the Geckos at 2 amps, the ability to run a 72 volt supply means great performance at ALL speeds, not just a slow crawl like with 24 v. The difference is truly unreal.
    Given the fact you can run a broader variety of motors with the Geckos, making surplus motors a good option, you may well wind up not too far off of the cost of the Xylotex kit anyway. Even if you go with all new motors, the difference is only going to be a couple of hundred bucks, or about half again more, for about three times or better the performance. If you can at all afford it, it's silly not to go with the Geckos. Has the side benefit of the legendary reliability and service too, but the voltage difference is the real meat of the issue here for a router.
    Jun 2007
    Thanks jhowelb and Stepper Monkey,
    I think I'm just about sold. I really prefer quality. Also thinking that if I upgrade the table later I can use the same equipment if I want to do something bigger.
    jhowelb. I was under the fasle impression that you had to have a controller, drivers, and a computer. Ignorant me... not thinking the controller was a computer. Guess it is just a breakout board between the RS-232 port and the drivers. Thanks for your help again.
    Jan 2005
    Now, you will need control software.
    My recommendation is Mach 3.
    Demo version is free to download and use. with the demo limit of lines of code you can still do lots of work till you convinced and buy the license. You pop the license file into the Mach directory and off you go.
    Feb 2008
    How are the Gecko drives connected to the computer? Do I need breakout boards? If so, which breakout board should I buy?
    Dec 2007
    I bought cnc4pc's, designed for gecko's (I think about $10-$15 less than the other boards.) as they have opto-iso built in. Makes wiring a snap. I run two machines with gecko's.
    Jan 2005
    Quote Originally Posted by jeffmorris View Post
    Geckos are connected by way of the printer port. The are already opto isolated and therefore have a thresh hold voltage for operation that some computers have difficulty producing at the printer port. Both these sites have a board that will do.
    http://www.pmdx.com/
    http://www.cnc4pc.com/Store/osc/
    Oct 2007
    Quote Originally Posted by chester1957 View Post
    Same here, it's the C11G breakout board and I'm running 3 203v's and have had absolutely no problems. Well ok, one problem but it was entirely my fault. I accidentally connected my Z axis polarity wrong and popped the inetrnal fuse. Even though it was my fault Gecko sent a replacement fuse along with a couple of spares free of charge right away.
    I was just reading this last night regarding a Xylotex customer-
    Very, VERY Unhappy in Illinois
    This thread was originated by the owner of Gecko and shows his dedication to the industry and interest in customer service-
    Anyone kill a G203V yet?
    Gecko is currently developing some low price (under $50) lower power (about 3.5 amp, 60 volt) drivers that should be hitting the market in the next few weeks. I plan to buy a couple for a small lathe conversion I have been toying with.
    Good luck and Go Gecko...
    Jun 2007
    Gecko drives will actually far outperform the other drivers even at the same voltage. It really is astonishing.
    Feb 2008
    I found out that the PMDX-131 BOB isn't compatible with Gecko 203V boards. I like the way that the PMDX-131 BOB is connected to Gecko driver boards.
    Jun 2007
    What connections is it missing?
  • Page 1 of 3 123 LastLast
    1. Constant torque. Is it worth the cost?
      By MrWild in forum Phase Converters and VFD
      Last Post: 06-30-2011, 12:34 PM
    2. gecko drives
      By eloid in forum Gecko Drives
      Last Post: 02-19-2007, 09:42 PM
    3. Gecko 202 drives
      By Pete Stenabaugh in forum Gecko Drives
      Last Post: 07-29-2006, 08:39 PM
    4. Low Cost Stepper Drives
      By drk in forum Stepper Motors and Drives
      Last Post: 08-01-2005, 08:48 AM
    5. Gecko Drives
      By ninewgt in forum Gecko Drives
      Last Post: 06-23-2003, 09:12 PM
