Results 1 to 7 of 7
Thread: router mounts design
    Mad scientist Dan S's Avatar
    Oct 2003
    I’m designing a set of router mounts, to work with the Porter-Cable 69X, 89X, and 751X series routers, after I finish them I’m going to post a copy in the download section.
    I know the motor casings are 3.5” in diameter but I need to make sure I leave enough space, so the head clears the mounting plate. Can anyone tell me what the maximum diameters of these models are?
    Attached Thumbnails Attached Thumbnails router mounts design-1.jpg   router mounts design-2.jpg   router mounts design-3.jpg
    Dan Sherman
    Apr 2003
    UK
    I have no idea on the distance you require, but I do have a quick tip! Check your distance between the rear bracket mounting holes, and the joining holes on each side so there is enough clearance to get a decent size allen key in there. I have a similar bracket on my machine, and the allen key is a tight fit - possibly too tight.
    Hope it helps
    Mar 2003
    Shelby Twp, MI....USA
    For starters, the 7518 has a 4" D body. The 690 and 890 are 3.5".
    I just measured them all, and they'll all fit with a 1/2" clearance but if you need to mount them at a different angle, they all may need up to 1". The 892 maybe a little less.
    Oct 2003
    Ok, I got another question. If I upload this zip file to the download section can I go back and change it? Because I think I might want to add a g code file to it later.
    The zip file contains a dwg, dxf, and a readme. The smallest radius is 0.25” so they can be milled with end mills up to 0.5” in diameter. The mounting holes are sized for standard #10-32 allen bolts.
    Kong:
    As the files are now, there is 1.75” of clearance. If you need more clearance than that you must have some big wrenches.
    Ger21:
    Thanks for the info. I have 15/16” of clearance, so I think I’m good to go.
    Attached Files Attached Files
    Dan Sherman
    Dec 2003
    Email me the DXF when you're ready and I'll cut them. 1/2 thick right?
    Proud owner of a Series II Bridgeport.
    Oct 2003
    CF
    What e-mail address do you want me to send them to? You can pm me if you don’t want to give out your e-mail address to the public.
    Dan Sherman
    Dec 2003
    My business email is webmaster@coldfusionracing.com
  • Posting Permissions
