Results 1 to 4 of 4
Thread: Choise the right linear guide
    Jul 2007
    Italy
    Hi guys.
    I'm trying to choise the best guide for the CNC that i'm developing.
    It will be made by alluminium.
    The CNC will be with a working area of 800x800mm and will also be a fixed bridge CNC.
    I found those data on HIWIN catalog but i'm not sure what linear guide best fit for my CNC.
    HGH 15
    Basic Dynamic Load 11.38
    Basic Static Load 25.31
    HGH 20
    Basic Dynamic Load 17.75
    Basic Static Load 37.84
    HGH 25
    Basic Dynamic Load 26.48
    Basic Static Load 56.19
    HGH 30
    Basic Dynamic Load 38.74
    Basic Static Load 83.06
    Someone can help me choising the right one? I can use the HGH 20? only 2 cm of linear rail will take all the weight of the alluminium?
    Jul 2007
    Italy
    Just for give an idea this is the draw of the base of the CNC.
    I'm still developing it sorry i don't have more pictures.
    Attached Files Attached Files
    esm
    esm is offline
    Registered esm's Avatar
    Nov 2007
    Cardedon, you'll get better response if you make it easier for people to help you. What are you cutting (weight)? Visuals are great, but I don't like downloading a zipped folder to view pics (viruses/lazy). Can you post some jpegs or .dxf's of the your machine and the parts in question? Any other information you have will help, motor size, drive method, gearing, spindle.... anything.
    "I've got a long way to go and a short time to get there, We're gonna do what they say can't be done."
    Dec 2006
    I don't know the engineering specs or how to calculate loads and all that jazz. But I have a great mechanical mind and when it comes to those things, linear bearings, I try to go as big as my budget will allow. Now that assumes you're cutting wood, if cutting aluminum I would certainly find someone to do the calculations. What I would do is design my machine and then call one of the manufacturers. A lot of those companies would be more than happy to give you the right infor and figure out what would work in your situation. A lof the high end linear bearings such as Thompson can take extremely high loads, more than you would think.
  1. Combined Rack and Linear Guide
    By Dizzy_G in forum Linear and Rotary Motion
    Last Post: 11-23-2007, 11:33 AM
  2. Fuse And Linear Guide
    By Alex S.A in forum General Metal Working Machines
    Last Post: 03-18-2007, 06:48 PM
  3. HIWIN linear guide too tight
    By IQChallenged in forum Linear and Rotary Motion
    Last Post: 12-21-2006, 03:19 PM
  4. 8 Foot linear guide system?
    By jkpugh in forum Linear and Rotary Motion
    Last Post: 12-10-2006, 07:38 PM
  5. Support for linear guide
    By wile_e in forum Mechanical Calculations/Engineering Design
    Last Post: 01-29-2005, 06:30 PM
