Hi
Check out www.solsylva.com they have some good info about limit switches.I use 5 limit switches on my machine, 3 function as limit/home switches.The Mach3 Mill manual also has good info about the limit switches, also check out the inputs video from the artsoft website.My switches are hooked up in series and use the Normally closed pins on the switches.Hope this helps
Edmond
LinkBack URL
About LinkBacks
