Results 1 to 6 of 6
Thread: My first CNC design "TCNC v5"
    Jan 2006
    Austria
    Hi CNC Zone
    After many days, months and a few years of reading and learning from this community, i decided to make my 5th design. The first 4 designs will stay virtual ;-)
    I still don't know how this will all work out, but i decided to give it a try.
    I already started to buy the things that i will need and will post all my progress here. The biggest problem that i am having right now is to find all the local suppliers here in Vienna, Austria. Today (06.02.2008) i found a big aluminium supplier. I will also post this info here for anyone that is living in my area.
    I named it TCNC v5 meaning (Table CNC v5).
    Not a very interesting name, but i had to give it some kind of a name :-)
    Well, that's it for now.....i hope you like it.
    Aug 2006
    What are the materials and rough dimensions?
    Gold Member Mr.Chips's Avatar
    Sep 2003
    USA Tucson AZ
    Smile Welcome to the CNCZone
    Welcome to the CNCZone,
    Good looking design. It contains all the componets to make a good running machine.
    One thing that I might suggest would be to add a little support on the side uprights, MDF has proved not to be strong enough in this area on the builds here. They are adding a angle iron brace here to reinforce it see picture below.
    Keep us posted with pictures when you start your build
    Good luck
    Attached Thumbnails Attached Thumbnails My first CNC design "TCNC v5"-mrz.jpg
    Jan 2006
    Austria
    Quote Originally Posted by jdell42 View Post
    Sorry....have to get used to documenting stuff, i'm more of a tech guy :-)
    And about the side support... i already thought about that, and i will put some kind of iron brace support which i will also use for the cabling.
    Working area should be around 50X40cm (20X16in)
    And the material is MDF or something similar. Whatever i can find here :-)
    Aug 2006
    As Mr. Chips states you got a fairly solid start. Take his advice on the gantry.
    I also think you need a top and bottom drawer in the cabinet to finish it off
    Jan 2006
    Austria
    A loooong time has passed by, but i finally got to it ...i started my build
    The only thing that changed is the size a bit.
    I will build 50cm X 100cm....i just need a bigger working area
    I hope it will start it's work in a few weeks.
    Here are a few pics:
    My first CNC design "TCNC v5"-tcnc_1.jpgMy first CNC design "TCNC v5"-tcnc_2.jpgMy first CNC design "TCNC v5"-tcnc_3.jpg
    Nothing is impossible....exept that the state of your mind makes it so.
    1. "low end" HF Spindle or "high end" router for about $1000?
      By biomed_eng in forum DIY CNC Router Table Machines
      Last Post: 01-06-2012, 01:15 AM
    2. BattleAxe "aka" Ball and Chain "aka" the wife.
      By ZipSnipe in forum CNCzone Club House
      Last Post: 05-18-2008, 10:53 AM
    3. G320 "common" or "+5vdc" why do they vary?
      By beezerlm in forum Gecko Drives
      Last Post: 01-12-2008, 05:00 PM
    4. "BRAKE BOARD" NEW Design for MACH3
      By Chivo in forum General Electronics Discussion
      Last Post: 04-08-2007, 01:01 PM
    5. Replies: 4
      Last Post: 05-17-2006, 06:19 AM
