Results 1 to 3 of 3
Thread: plans for cnc router/mill
    Apr 2003
    CALIFORNIA
    Smile plans for cnc router/mill
    Hello every body,
    Have any one seen the plans for home machine at cnckits.com. They are talking about xx,y,z machine, the double x added for strength. Sugesting two motors, isn't that hard to syncronize?
    Regards,
    Gomez107
    Apr 2003
    Sedona, AZ
    No, there is really is nothing to sync... the two motors are both hooked up the the same x axis out (on the) controller. So, both are sent the same pulses at the same time. Since both motors are the same specification, and the same size screws, nuts, belt drive or rack and pinion setups are used, it really can't go out of sync unless a motor misses a step. You could also have a motor on each end of a single screw and one motor is wired opposite (backwards). The same principle applys.
    -Marc
    Apr 2003
    CALIFORNIA
    Marc,
    Thanks a lot!, I am planning to built my own cnc router and I think this plan may be the answer. I will do more research first.
    Thanks,
    Gomez107
  1. Looking for people wanting to develop new plans for a cheap cnc
    By Hack in forum Open Source CNC Machine Designs
    Last Post: 02-17-2010, 05:15 PM
  2. Help to choose CNC Router Plans.
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 01-20-2010, 02:50 AM
  3. Poll: What Plans Do we Want Cheaply?
    By vacpress in forum Polls
    Last Post: 07-10-2006, 03:19 PM
  4. 4 stroke engine: castings & plans
    By motordude in forum I.C. Engines
    Last Post: 03-02-2004, 11:08 AM
  5. New 4 X 8 Router Plans
    By ninewgt in forum Product and Manufacturer Announcements
    Last Post: 09-14-2003, 12:59 AM
