Results 1 to 3 of 3
Thread: New man on the block
    Feb 2006
    U.S.
    O.K. here we go I have been hanging around here for awhile and now it is time to get going, I would like to build a setup with aprox, a 24 X48X 4-Z , machine I have scrounged up enough linear slide for the X, Y, & Z axis, now I really could use some of the important help with what I need to drive this thing, I would like to use aluminum ext. for the frame, and gantry, possibly use acme screw to move the carrige or a rack, the machine would be used for wood and plastic.
    A set of some sort of plans, some info on the electric end of things, and the best software, IS ALL I NEED-ha not too much to ask.
    Any help and direction is appreciated
    Aug 2006
    Sounds like a Joe2006 is what you need....cuts wood and plastic easily at 60-80 ipm
    You won't need the linear slides.
    If you go with a Hobby CNC kit the controller gets real easy.
    Software you will need is Mach3, some CAD (lots of free versions) and a CAM package..
    Cheap one is SheetCam.. http://sheetcam.com/ but vcarve is what I use most now.. http://www.vectric.com/
    Feb 2006
    U.S.
    I will check into it seems like a waste for the linear rails to go by the wayside oh well I will just archive them
  1. V-block
    By jinu117 in forum Work Fixtures and Hold-Down Solutions
    Last Post: 12-15-2007, 07:50 AM
  2. New Kid on the block
    By GEORGETOUBALIS in forum CNCzone Club House
    Last Post: 09-14-2006, 04:46 PM
  3. Help with block
    By Max-DK in forum TurboCAD/CAM
    Last Post: 03-24-2006, 11:10 AM
  4. RS232 program block by block
    By smoregrava in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 12-22-2005, 01:52 AM
  5. The new guy on the block
    By ThoR in forum General Metal Working Machines
    Last Post: 01-23-2004, 05:29 PM
