Results 1 to 12 of 12
Thread: Joystick Control
    Mar 2004
    Joystick Control
    Hi all,
    I was looking around in the garage and I found and old joystick. And then I thought, is it possible to control a CNC machine with one of these? I think I have seen it before. Does anybody know if you can use a joystick to controll the motors. It may not be so usefull for a Router, but if you had a robotic arm or something it would be so cool.
    Thanks.
    Jun 2004
    I have some old code for controlling a printer port
    via joy stick some where but I didn't write
    it was a joint thing we used for out printer port interface
    back in highschool
    hmm I think I just found my break out board
    I may have a use for this thing after all
    if you want the code just shoot a pm and I'll send it to you
    pretty easy stuff we did it in grade 10 like 8 years ago
    Moderator ynneb's Avatar
    Feb 2004
    Oz
    If you use Mach2 it will enable you to use a joystick, or a gamepad, or other controllers.
    It will enable you to set the buttons to do many different things.
    Being outside the square !!!
    Mar 2004
    The Mach2 Breakout board or the software?
    Thanks.
    Mar 2003
    Shelby Twp, MI....USA
    The software supports all that stuff, but you'll have to wire it all up yourself.
    Mar 2004
    You mean I can use the same port for my joystick, in the computor, and the software will take the signals from the joystick, and send them to the driver? Without any additional boards?
    Thanks.
    Feb 2004
    Oz
    Yes.
    You can download Mach2 from here http://www.artofcnc.ca/
    This will give you a trial version that will alow you to use 100 lines of gcode. If you wish to purchase Mach2 it will cost you 150 bucks.
    Dont feel you will only be purchasing a joystick controller. Mach 2 is a complete program for interpreting Gcode and then sending signals to your driver cards. You need a program like this anyway, to make your whole CNC thing work.
    Mar 2004
    Would you be able to cut a circle with a joystick, or is it strictly up down, side to side and back and forth?
    Thanks.
    Feb 2004
    Oz
    Thanks.
    No. Not unless you are the world champion at playing playstation games. (Lots of hand to eye coordination) The joystick is mainly used for jogging the machine into position. I guess you could do some scribble cuts if that was what you needed.
    Mar 2004
    Oh, so you could just jog the machine to what you want as your home (start) position, if that is correct?
    So, the joystick does have the capability to run the multiple motors at once and not one at a time eh?
    Thanks.
    Registered strat's Avatar
    Oct 2003
    i just picked up on the prg . works great i have an old suncom joystick i use on it its an F15-Talon has 3 axis 2 which are programable to keystroke so full control from the stick the one thing i wanna do is get one of the buttons programmed for the spindle on /off
    Jan 2004
    Check out what Dave has to say about it at www.buildyouridea.com
    Stop talking about it and do it already!!!!!
    1. G-Code to DXF
      By WayneHill in forum OpenSource Software
      Last Post: 05-20-2013, 10:28 PM
    2. Visual Basic Controller Project
      By dwwright in forum Visual Basic
      Last Post: 02-14-2011, 02:24 PM
    3. CNC Glossary
      By CNCadmin in forum CNCzone Club House
      Last Post: 03-09-2008, 04:08 PM
    4. Fadals new Augusta control or 104d
      By Scott_bob in forum Fadal
      Last Post: 09-29-2007, 05:36 PM
    5. HAAS Indexer Prodramming / Control
      By CAMmando in forum Haas Mills
      Last Post: 06-10-2003, 11:22 AM
