Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: Test cutting files. ( Webdings )
    Moderator ynneb's Avatar
    Feb 2004
    Oz
    I have made a test cutting file for those who have made a CNC router and want to see it do somthing better than cutting a circle or a square.It is a 200mm x 200mm square with lots of webding fonts engraved onto it. You can use this file to show your friends your machine in action. It will demonstrate lots of movement.
    While it is in the downloads section the link seems to be not working. I will put it in this thread in the mean time.
    I advise any downloaders to read the txt file first, b4 they run the test.
    EDIT: Because there is lots of small pictures, It may be better to scale up the size to the biggest your table can handle. Otherwise you may find the pictures will lose detail in the etching.
    I recomend a v bit to be used with this file. The pointiest one you can get.
    Attached Thumbnails Attached Thumbnails Test cutting files. ( Webdings )-clipboard.gif
    Being outside the square !!!
    Feb 2004
    Oz
    Oh, and here is the file.
    Attached Files Attached Files
    Feb 2004
    Oz
    A chess board.
    Attached Thumbnails Attached Thumbnails Test cutting files. ( Webdings )-chess.gif
    Feb 2004
    Oz
    Here is the chess board file.
    Oct 2003
    Sweden
    Thanks Benny! Those files will come in handy.
    BTW, is it possible to cut ellipses with the G2/G3 commands somehow? Or only circular arcs? Trying to learn some G-code.
    Arvid
    Nov 2003
    Thanks Benny, have to give that a try.
    Anyone have a small 3D part file they would share? I would like to see my machine cut a 3D part but I don't have any 3D software (yet). If it was ready to be run on Mach2 that would be great.
    Dec 2003
    InventIt, I watched your machine progress and I must say you have built a very nice router!
    Here is a small 3d file in IGES and STL. It is 50x50x10mm with a multi-angled face.
    www.coldfusionracing.com/CNC/3d.IGS
    www.coldfusionracing.com/CNC/3d.STL
    Proud owner of a Series II Bridgeport.
    Feb 2004
    Oz
    Hey Inventit, tell me what tool you will use for the 3D routing and I will make the path according to that bit.
    Arvidb, Sorry I cant answer your question, because I dont know how to write Gcode. I use a program to spit it out. This is one of the reasons I have put up these files, for people like me who cant write gcode and want to test out their machines.
    With software to write the Gcode, I am not sure I will ever actually ever manually write anything. I guess its like writing HTML, you can do it by hand, or get a program to do it for you.
    Nov 2003
    Thanks Cold Fusion, and thanks for posting the files. Unfortunately I don't have any way to turn the stl or igs files into gcode
    ynneb, I have ball end mills in 1/16, 1/8, 3/16, 1/4, 1/2" and also straight end mills too. Thanks I really appreciate it.
    Registered whiteriver's Avatar
    Aug 2003
    Anyone got any 3d models to share.
    Donny
    Aug 2003
    Here is a tiger to cut out. its 10"x7.5"x2" It will work with a mach2 controller. Use a 1/4" ball mill. For material I would suggest extruded foam 2" thick. You can get it cheap at home depot. Even expanded foam will work fine. Set zero at top left of the part. Zero is at the top of the surface of the stock.
    Good luck and have fun.
    Donny
    Feb 2004
    Oz
    Thanks for posting that Whiteriver, I had meant to post something 3d, but hadnt got round to it.
    Good job.
    EDIT: It seems the zip file is corrupted. Could you please test it and re-upolad it. Thanks
    EDIT: Sorry, I just redownloaded it and it is fine.
  • Page 1 of 2 12 LastLast
    1. How to view iges files
      By Hack in forum TurboCAD/CAM
      Last Post: 05-07-2011, 04:03 AM
    2. Having trouble cutting aluminum sheet
      By fastturbovet in forum General Metalwork Discussion
      Last Post: 06-14-2005, 11:33 PM
    3. CNC router deflection calcs and cutting loads?
      By Linus in forum DIY CNC Router Table Machines
      Last Post: 09-10-2004, 11:08 AM
    4. power supply test
      By dlenox in forum DIY CNC Router Table Machines
      Last Post: 04-27-2004, 09:06 PM
    5. Do you account for climb cutting in G code?
      By fyffe555 in forum DIY CNC Router Table Machines
      Last Post: 11-06-2003, 08:21 PM
