Results 1 to 1 of 1
Thread: Finally starting
    Nov 2005
    canada
    Finally starting
    I have finally started building a machine. The drawings are always a work in progress as my ideas keep changing. However, I am forging ahead. I have all of the linear bearings, ball screws and nuts, couplings, gears, racks, bearings,drive shaft, most of the small burnings and the limit switches. Will be using 495oz steppers on this build. I am hoping to use Mach3 and the Vectric suite. My design incorporates an equalizer shaft on the X axis to compensate for driving on one side. This allows me an open table. The table on this design is arbitrary, you could put a stump in a wheelbarrow and carve it!
    TTFN.
  1. Finally!
    By MrWild in forum LinuxCNC (formerly EMC2)
    Last Post: 05-12-2007, 08:42 PM
  2. Finally!!!!!!!!
    By Cyclone in forum DIY CNC Router Table Machines
    Last Post: 01-23-2006, 01:17 PM
  3. My router is finally starting to be built
    By phantomcow2 in forum CNC Wood Router Project Log
    Last Post: 01-20-2006, 06:21 AM
  4. PCB. finally, oh finally
    By MrWild in forum General Electronics Discussion
    Last Post: 12-13-2005, 08:37 PM
  5. Finally starting on router project
    By ehiebert in forum DIY CNC Router Table Machines
    Last Post: 04-10-2004, 08:07 PM
