That's why they call it work.
I find that WD40 is a good tapping fluid for aluminum.
Gary
I got 32 taps to do at 5/16-18 for my TSlots legs. Then I have another 24 at least for other parts. Doing this by hand is taking forever. I tried using a little oil. It does seem to help a little.
Any other tips?
On the upside, it's a no-brainer. So I can just sit in the garage during the sweltering heat and think of happier days while I work. LOL.
Gary
I think if I faced that job I'd take the time to make a jig that would start the tap square and use a cordless drill with the clutch set light to do the job.
Get some WD40 and a long movie.
Proud owner of a Series II Bridgeport.
I agree with using a cordless drill, preferably one with a clutch. You would be done in an hour or so if you are careful
Spiral taps and proper thread cutting fluid.
Makes all the difference in the world. Makes WD40 and old standard taps seem like water in comparison.
I only buy spiral now myself. big difference.
TAPMATIC!! Great tapping fluid. No sticking. No breaking. Like screwing a nut on a bolt. Get the kind for Alu.
Mark
DMG Designs
League City, Texas
Just guessing -- you want a cleaner look than using the 90 degree angle brackets they make? I admit that gear can be a bit pricy - with all the screws, and bits, BUT - you have nearly infinate adjustment range in all three axes - and you can use those to help square the rig too. On the other hand, I did some of that "Work-stuff" too so I could mount end fittings for motors, etc - tapped using WD-40.
If it moves and shouldn't - Duct Tape it . If it should and it don't - WD40!
Cheers - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Buy good taps. If the ones you are using came with that tap wrench then you sould invest in better quality. I would suggest two fluters that is what I use when I need to tap 80/20 at work.
I aplogise for ragging on your tap wrench but it looks like the kind you get in the cheap Chinese import tap kits and I know those taps are lousy at best.
TAB:
"...it looks like the kind you get in the cheap Chinese import tap kits..."
I'm so embarrassed! LOL. Yes, the handle is from a cheap chinese import tap kit (ala Harbour Freight). The tap is from the local hardware store because the kit didn't have what I wanted in it. I think the tap is name brand.
when i'm tapping metal i use a mix of beeswax and kerosene works really good
Have you tried selftapping screws, same as the industries uses I have seen it in Hewlett Packard instruments and some japaneese euqipment they often use it when aluminium profiles is used.
