Results 1 to 2 of 2
Thread: Simple test axis
    Apr 2004
    Michigan
    Simple test axis
    This is my axis I use to test stepper motors and drivers. Made with 3/4" birch plywood, 1/2" drill rod, 1/2"x10TPI ACME screw and bronze bushings purchased from Sears hardware. I tapped a ACME nut out of delrin and used a skateboard bearing as a simple thrust bearing assembly.
    The stepper motor was a recently purchased Ebay find. It's an older Vexta PH265-05B-C12 1.4V 3.8amp nema23. No torque rating on the motor but I guess around 75oz/in. They were cheap, 4 for $45 +$15 shipping. Plus they have nice working HP encoders on them which I will remove and use on some servo motors I have. Pretty good deal since new encoders cost more than that.
    Using Turbocnc, I was able to move the axis at 75IPM with a 20lbs weight to simulate a gantry load. Over 100IPM without the weight. The stepper motor driver is our own custom designed 3amp microstepping driver. The stepper motor easily spins over 1000RPM, not too bad for $15 each. I'm sure it will go much faster but my laptop can't put out higher step pulse rates.
    Jim
    www.embeddedtronics.com
    Apr 2004
    Michigan
    another view of the motor and driver
    Jim
  1. Beginner Troubleshooting and Building Considerations
    By coherent in forum FAQ of CNC Machine building
    Last Post: 11-10-2011, 02:27 PM
  2. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-13-2005, 10:08 PM
  3. Add a second set of rails to X axis..need advice.
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 05-31-2005, 08:11 PM
  4. Need simple, 4th axis example
    By radracer in forum BobCad-Cam
    Last Post: 03-16-2005, 09:43 AM
  5. 2.5-Axis vs 3-Axis
    By JamesBond in forum General Metal Working Machines
    Last Post: 07-26-2003, 08:09 PM
