Results 1 to 2 of 2
Thread: Some basic questions about (DIY) cnc
    Aug 2007
    Croatia
    Hi all!
    How is the material fastened to the surface board ? (clamps ?)
    How its assured that cutting tool does not scratch the cutting surface board ? Are some kind of spacers used ?
    What kind(specs) of step motors should I buy if machine is going to be used for cutting aluminium, plexi and wood (up to 5 cm thickness), what kind of router ?
    Does using bigger/stronger motors/router decreases accuracy (eg. can the same machine be used to make el. guitar body and PCB)?
    Where can i find ABC of (DIY) CNC ?
    thanx
    Dec 2006
    Clw, FL
    1. Clamps, screws, could also be vacuum clamp/table
    2. I guess thats why its called spoil board, it can take slight hits, than you resurface it.
    3. I'll let some one else answer that
  1. Very Basic CAM Questions
    By kochevnik in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 06-26-2008, 08:59 AM
  2. basic electronics questions..
    By tranceamerica in forum Stepper Motors and Drives
    Last Post: 07-02-2007, 11:35 AM
  3. New guy asking basic questions.
    By Crazybillybob in forum PicStep Controllers
    Last Post: 02-22-2007, 11:28 PM
  4. Basic Questions
    By NinerSevenTango in forum FeatureCAM CAD/CAM
    Last Post: 01-05-2007, 10:53 PM
  5. Basic questions (new guy)
    By mattsgarage in forum CNCzone Club House
    Last Post: 04-08-2005, 02:27 PM
