Results 1 to 3 of 3
Thread: Where to get a vacuum pump
    Registered whiteriver's Avatar
    Aug 2003
    Question Where to get a vacuum pump
    Well my 3hp vacuum pump is not cutting it. Would like to up to a 10hp to fill the bill.
    Where would be a good place to get one besides e-bay. Need to be able to suck through 3/4 mdf and still hold a sheet of plastic steady.
    What kinda price would one expect to pay. $2000?? $3000??
    Donny
    Registered Jennifer's Avatar
    Jun 2003
    San Diego, CA
    We use a vacuum from Becker pumps. Also, ultralight MDF works really well as a spoilboard...there's maybe a .02 skin on either side that once removed allows for quite a bit of flow through.
    Good luck.
    Jen
    Registered NeoMoses's Avatar
    Apr 2003
    Prolly' in the Shop :)
    I was just looking at some vacuum pumps at MSC direct (www.mscdirect.com). They started at a few hundred dollars and went into the thousands depending on how many CFM you are needing.
    My name is Electric Nachos. Sorry to impose, but I am the ocean.
    http://www.bryanpryor.com
  1. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 11:30 AM
  2. Vacuum Hold down for wood.
    By HomeCNC in forum DIY CNC Router Table Machines
    Last Post: 07-24-2007, 12:16 AM
  3. Venturi Vacuum Systems
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 09-24-2004, 09:17 AM
  4. Would this make a good vacuum pump?
    By CNCadmin in forum DIY CNC Router Table Machines
    Last Post: 09-13-2004, 03:37 AM
  5. Pump for vacuum fixture
    By DAB_Design in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 07-04-2004, 07:17 AM
