1. You can use a smaller THK slide to get the similar strength as a round way bearing. Check the spec's.
This helps in certain instances where space is a problem.
If you use a supported Thomson bearing, it will work just fine.
For DIY use, its whatever you can find and afford.
LinkBack URL
About LinkBacks
