Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: Building Router Table
    Apr 2004
    MO - USA
    I AM A NEW USER LOOKING FOR GUIDANCE ON BUILDING A PC BASED SYSTEM THAT IS EAZY TO RUN AND INTERACT WITH OTHER SOFTWARE.
    I HAVE MANY ?
    I WANT TO END UP WITH A HIGH TORQUE SYSTEM (1000 OZ) WITH 5-6 AXIS OF CONTROL, BUT WILL START WITH A SIMPLE 3 AXIS SYSTEM (HOPEFULLY THAT IS EXPANDABLE).
    I HAVE LOOKED AT MANY DIFFERENT MONTION CONTROL SYSTEMS AND I AM CONFUSED ON WERE TO BEGIN.
    THE MAJOR PROBLEM IS HOW DO I MATCH UP THE CONTROL - DRIVER - MOTORS?
    I HAVE READ IN THIS FORUM THAT HIGH VOLT - LOW AMP MOTORS ARE BETTER.
    P.S. THE PRO BUILDERS IS MY BUSINESS NAME SINCE I AM A BUILDER AND ONBODY CAN PRONOUCE MY LAST NAME. NOT TO BE COINCIDED.
    Registered whiteriver's Avatar
    Aug 2003
    MO is that montana. If so what part.
    If it was me i would use nema 34 motors and a 2 to 1 gear reduction thu a timing belt. Use gecko 201 microstepping drives or wait for the new Gecko Vampire drive. Use mach2 to control it. It has the abiltity to run 6 axis. Then pick up a power supply off e-bay. You can sometimes get them for $50 to $100 from the telcom industry. I had 2 nice ones given to me for free. Now I have a spair. To bad they are over 200lbs each. Get a cambel breakout board then your good to go on the electronics.
    As for the table you did'nt mention size or need for rigitiy. Sure there are guys here with more knowlege than I that will point you in the right direction based on your needs.
    Donny
    Apr 2004
    MO - USA
    THANK FOR THE INPUT!!!
    I HAVE VIEWED http://www.artofcnc.ca/product.html SITE AND THE MACH 2 PRODUCT. IT LOOKS TO BE ABOUT EVERTHING, HOWEVER THERE ARE NO PICTURES OF THE PRODUCT. I DO NOT UNDERSTAND IF IT IS A PCB MONTION CONTROLL CARD OR A SOFTWARE PROGRAM?
    IF IT IS ONLY THE SOFTWARE SIDE DO I STILL NEED A MOTION CONTROLL CARD OR NOT?
    THANKS AGIAN FOR AN HELP
    Apr 2004
    MO - USA
    SORRY IT IS MISSOURI NOT MONTANA
    THANKS AGAIN
    Registered balsaman's Avatar
    Mar 2003
    Hit the caps lock key once
    Mach 2 is software. You don't need a motion control card but you do need drivers such a a xylotex or gecko's.
    Low volt, high current is best for speed.
    Describe what you are building and from what materials, what you plan on doing with the machine and your budget and it will be easier to help you.
    Eric
    I wish it wouldn't crash.
    Apr 2004
    MO - USA
    I am planning on building in protype 4'x8' min moving ganty table with a 12" x axis for heavy duty mdf circular work to start with. I was planning on using a 2 to 1 ratio with timing belts and pulleys. I basically have the mechanics worked out it is only the techie part I could use some help with.
    So the mach 2 does the work of a motion control card only it uses the pc's resources so to speak. it will tie up the processor (no big deal)?
    If this is true I will need a driver for each motor or axis, right?
    What type of motor unipolar , bipolar, hybrid, ect?
    Also, at some time I would like encoder feed back in the future, I think?
    Thanks for the input, mach 2 sounds like the way to go to get your feet wet.
    Mar 2003
    Mach 2 is as you describe. It will tie up the CPU.
    You need a driver for each axis. have a look at www.geckodrive.com
    Unipolar or Bipolar would work with gecko drives
    No need for encoders on steppers, and there is presently no software that supports closed loop systems. If you use servo's you will need encoders, but they go back to the drive, not the PC.
    Build the machine first, purchase motors and drives last.
    Eric
    Apr 2004
    MO - USA
    Thanks for the input. You guys have saved me alot of money compared to what I thought I needed. I believe I have enough info to get started.
    If I have any more questions I will be sure to use this forum.
    Thanks again!!!
    Registered pminmo's Avatar
    Jun 2003
    St. Peters, Mo USA
    PROBUILDER,
    Where abouts in MO, I live in St. Peters
    Phil
    Gold Member chuckknigh's Avatar
    Apr 2003
    Essentially true. What Mach2 and any of the other programs do, is to generate a signal. You see, a stepper motor requires a 2 part signal in order to move...one tells it to move a step, the other tells it in which direction.
    The driver board (1 per motor...) reads this instruction, and generates the necessary voltages on the right pins, at the right levels for the motor. Needless to say, your parallel port couldn't drive a very big motor directly...if at all. (inductive loads on computer ports are not a good idea)
    Each motor ties up 2 lines on your parallel port -- that's where the signals come out.
    Don't discount the simpler software, either. TurboCNC is very good, and is shareware...free and fully functional, with a $20 (I think) registration fee.
    A LOT of people on this site use TurboCNC.
    -- Chuck Knight
    Mar 2004
    Keep in mind that Mach2 runs on an XP computer (I.E. newer). With TurboCNC you can use an old 233mHz DOS box and just dedicate it to the router table. If you want it networked, install Win98 and boot to dos when you want to run the table.
    Bill
    Mar 2004
    Could you give some more info on the Gecko Vampire Drivers. When do they come out, what do they look like, price, what can they handle, any links?
    Thanks.
  • Page 1 of 2 12 LastLast
    1. My first Router / Plasma Table Buildup...
      By InventIt in forum DIY CNC Router Table Machines
      Last Post: 01-04-2009, 11:20 PM
    2. Collapsable router table?
      By samualt in forum DIY CNC Router Table Machines
      Last Post: 03-27-2007, 10:02 PM
    3. Building My Second Router
      By snazzyguy in forum CNC Wood Router Project Log
      Last Post: 04-30-2006, 06:32 PM
    4. How many building the cad cut cnc router?
      By jsatter in forum DIY CNC Router Table Machines
      Last Post: 07-26-2004, 04:10 PM
    5. My first CNC router: 1.5 years building
      By hddjohns in forum DIY CNC Router Table Machines
      Last Post: 04-03-2004, 11:18 AM
