hey Coffin, let me tell ya the route I decided to take. Rather than jumping right into CNC, I decided to take the machinist (learning the trade)route. Why? Becuase you need to learn the correct way to measure, set up and make jigs and such. I now work nights at a Mold shop and have access to Bridgeports ,Surface grinders and a huge lathe. They have several CNC machines but these are huge work horses and I,m just breaking the surface of learning G-Code(very important when it comes to cnc). I,ve pondered for months on end trying to figure the correct machine that will make me happy and overall I decided that a cnc router one that I,m still designing Zip's CNC Router
I also plan to convert a mill that I already built
My Manual small mill project
Tooling is expensive and your project will not be cheap even through there are people here making cnc router and foam cutters out of mdf(compressed particle board) and plastic. I think it depends how accurate of work you plan to do. For basic tooling you could start off with dial caliper, indicator/magnetic stand, square and a steel rule. If you,re not concerned about accuracy than mdf or plastic will work fine. For stepper kit heres a link to cheap ones that will work fine http://www.hobbycnc.com/
HobbyCNC.com
Anyway really think about how much your willing to invest and what you,ll get back out of it. So far I have probably$2000 in Mill, lathe and tooling. Have I made any money? NOPE! But its what I wanted to learn and do. Do I plan to make money? Yes but I,m carefully planning and researching product and product developement. Anyway hope some of this helps(and you thought your post was long)
LinkBack URL
About LinkBacks
machine and some type of cutting device removes material from the stock to bring it down to the desired shape. (router, mill, EDM, hot wire, etc…) FYI: You will need to learn a few tricks for fastening the stock material to the machine and how to tell the machine where you put it.
