Results 1 to 4 of 4
Thread: 8020 BBR Router Build
    Apr 2007
    Just starting a new build - somewhat based on hack's 8020 design. I've been lurking for quite some time - read and re-read all the 8020 builds. I'm calling mine BBR as in bargain basement router. My goal is to have a completed machine for under $500.00. (Software not included) I know already I won't make that but I feel that it will come in under $600.00. I do not have formal plans at this point, planning on getting a majority of the materials of of 8020 garage sale on ebay - and I will be focusing on materials that are "reduced" and "on sale". (As long as they pass 8020's deflection calculator at .005 or less it's good enough for me)
    I have already purchased some 41" 4080 rails at a good price as well as some diy bearings, so the y footprint will be no more than 41". Trying to figure if I can push the x footprint out to 60" without losing too much accuracy or whipping 1/2 single start acme too much. Dumpster's nuts, some angle iron, couple motors, controller, some wire, What Could Go Wrong
    Planning on 270 - 425 oz motors anybody had any experiece on using different motors on different axis? I dont think i'll need the 425's for the y and z but sure want it for the x. Then again I may go with hobby's 4 axis controller and just use dual 270's for the x. Will post more as the materials get purchased and plans get drawn......
    Registered ahren's Avatar
    Feb 2004
    If you're interested, I'll be launching my website this weekend with some inexpensive bearing blocks and motor mounts, both designed to mount directly to 8020 extrusion, for use with 1/2" ACME and dumpster nuts. Feel free to PM me if you'd like a preview.
    Best regards,
    Ahren
    Apr 2007
    Well the 8020 shipment came today! One long (over 8') box, havent opened it up yet, kind of like a kid at christmas. Leadscrews are on order as well as the delrin nuts. scored a deal on ebay - we'll see if it was a GOOD deal or BAD soon enough . Next up the controller and steppers - pretty much decided on the hobby board and 425 oz motors from kelinginc. Am planning the build to start the week of June 15th - wife will be out of town - just me and the dogs - will post pictures as appropriate - will also post a complete cost breakdown when i have the major purchases done. so far have spent about $240.00. for the 8020 structual, bearings and the x and y screws and nuts. Again goal is a sub $500.00 machine (if possible).
    Apr 2007
    Well here's a parts list so far - not ready for pictures unless you want to see uncut 8020.....
    8020 purchases to date $218.55 including shipping for:
    8020 Aluminum Make Your Own Bearing 40 S 40-6824 UN
    8020 T Slot Aluminum Extrusion 25 S 25-2550 x 48 N
    8020 T Slot Aluminum Extrusion 25 S 25-2550 x 96.50
    8020 Aluminum Make Your Own Bearing 40 S 40-6823
    8020 T Slot Aluminum Extrusion 40 S 40-4080 x 41
    8020 Aluminum Make Your Own Bearing 25 S 25-6725 A
    8020 T Slot Aluminum Linear Bearing 40 S 40-6826 A
    8020 Aluminum Make Your Own Bearing 40 S 40-6825
    Hobby CNC 4 Axis Stepper Control: $71.00
    Y Axis & Z Axis Lead Screws, Delrin Nuts and Z Axis Linear Slide: $80.00
    18/36 Volt Stepper motor power supply - Ebay Special $27.00 shipped
    Total Spent to date: $396.55
    Whats left to buy?
    X-Axis Lead Screws and Nuts - ~$40.00
    Stepper Motors ~$200.00
    Bearings ~$40.00
    Motor Couplers ~$30.00
    Decking for top...
    A little more 8020 for structure......
  1. Second router finished - 8020 Bearings
    By Hack in forum DIY CNC Router Table Machines
    Last Post: 12-06-2011, 12:32 PM
  2. Ahren's 8020 Router
    By ahren in forum CNC Wood Router Project Log
    Last Post: 09-23-2007, 11:10 PM
  3. 8020 Router, It's Finally Alive!
    By jcdillin in forum DIY CNC Router Table Machines
    Last Post: 03-26-2007, 06:49 AM
  4. 8020 cnc router table top
    By eloid in forum CNC Wood Router Project Log
    Last Post: 02-24-2007, 08:32 PM
  5. Results from using 8020 for a CNC router
    By WarrenW in forum 80/20, TSLOTS and other Aluminum Framing Systems
    Last Post: 01-05-2006, 09:17 PM
