Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: Corian as a slide?
    Gold Member chuckknigh's Avatar
    Apr 2003
    Corian as a slide?
    Well, a neighbor just had some Corian countertops put in, and of course I ran over and got some of the offcuts.
    Now I have a lot of "small-ish" pieces of a very hard, very smooth acrylic polymer, that's workable with carbide tools.
    Has anyone used Corian as a material for slides, or other parts of a CNC machine? It seems to have a number of desirable qualities, but I'm not sure if it's dimensionally stable...or how it would hold up under repeated abrasion.
    Any first hand experience?
    -- Chuck Knight
    Mar 2004
    Used it in kitchens and baths, it does scratch very easy so might not be too good as a bearing. I'm thinking it might make a good low vibration table if you could get some 1" or so thick.
    Bill
    Gold Member Bloy2004's Avatar
    Oct 2003
    Sturgeon Bay, WI
    I've worked with it..installing it in kitchens and bathrooms...
    It Does expand, although not to much.....always made the hold-down holes oversize for the expansion factor, or used flexible glues for fastening. It is really fairly easy to sand. Maybe with correct lubrication it MAY stand up to wear. As Bill says, it would make a great table but weight would require slightly bigger motor drives if the table is mobile. Easy to make t-slots into. Routes smoothly.
    Mar 2004
    Just a couple other thoughts about Corian. The shops that cast the counter tops can do custom sinks ect. So I was thinking, instead of MDF, how about a cast router table. Once you build a set of molds, the cost per machine would drop to the cost of materials. Could even offer a color selection.
    Bill
    Mar 2003
    Shelby Twp, MI....USA
    Corian isn't cast. And, it's very brittle. Bolting anything to it can cause it to crack if you're noit careful. And, imho, it's not very slippery.
    But I've thought about making molds to make composite parts for a router.
    Mar 2004
    Well I guess I'm thinking of a different product. The conter tops I'm thinking of is a resin material with the sink bowl cast in it. The color is add to give the impression of marble. You can cut it and drill it, bond it with a resin glue and polish the joint to the point that you can't tell where it was. We ordered the tops custom colored with a choice of bowls.
    I think it would be do-able as a small router frame, could also add fiberglass to the resin. Oh well, just blue-skying.
    Bill
    Moderator ynneb's Avatar
    Feb 2004
    Oz
    I would guess if it gets an abrasive dust in it it would deteriate rapidly. It may slide ok but I dont know for how long. The other thought was been resin It may react to the friction heat and lose its sliperyness while hot. I guess ideas like this must be tested to find out. Who knows. What about casting teflon sliders?
    Ger. I also am going to route some parts to make moulds for more machines. But thats a long way down the path. I also want to vacuum form plastic covers to give the machine a professional look.
    Being outside the square !!!
    Mar 2004
    Another thread here has a link to Moglice.com, moldable bearings. There are alot of photos of projects from customers, very interesting.
    Bill
    sol
    sol is offline
    Gold Member
    Sep 2003
    I have tried to use Corian for a number of parts.
    As an anti-back lash nut it fails, too brittle, very difficult to thread and then it rapidly wears.
    I have had good luck with it as a rail support in a panel cutter. I routed a cove in it and placed a rod of cold roll in the groove and it has held up for years..
    This area is very humid and with Corian the seasonal shrink and swell of wood is avoided, but overall it is an odd combo of properties: soft, brittle, stable, heavy and waterproof.
    Apr 2003
    Well, any other ideas for its use? If not, I'll just keep it around for future projects...
    -- Chuck Knight
    Feb 2004
    Oz
    Yes one Idea for its use. You could thow it at the neighbours cat.
    Apr 2003
    Nah...the neighbor with the cat is the lady that gave me the Corian. An inappropriate response, at best.
    -- Chuck Knight
  • Page 1 of 2 12 LastLast
    1. slide/ rail question
      By 2muchstuff in forum DIY CNC Router Table Machines
      Last Post: 04-14-2005, 06:25 PM
    2. T-Slot Linear Slide question
      By audball22386 in forum 80/20, TSLOTS and other Aluminum Framing Systems
      Last Post: 03-04-2005, 02:19 AM
    3. Cross slide work pc on rotary table
      By replicapro in forum General Metalwork Discussion
      Last Post: 07-08-2004, 06:30 AM
    4. Inexpensive Linear Slide Assemblies?
      By Homl in forum DIY CNC Router Table Machines
      Last Post: 06-03-2004, 02:05 AM
    5. Cross Slide Vise Recommendation
      By edge in forum General Metal Working Machines
      Last Post: 07-24-2003, 03:15 AM
