Hey guys,
Been lurking for a while. TONS of great info on this site... You've been a lot of help and inspiration.
I have a benchtop cnc 3 axis w/ servos and want to upgrade to a 4th axis. The manufacturer (Flashcut) wants about $2500 for the upgrade... The controler is already set up for the 4th axis minus the driver.
I have a bit of cnc experience with this and a plasma cutter, though electrics are my weakness...
The questions:
1. The drivers in the controler are made by Logosolinc.com and are labeled FC-182-1210 I called them and was told $429 for another driver. Seems steep! Is there another way that is compatible? I can get pics of inside of box, other electrics, etc...
2. How hard is it to retrofit a 6" or 8" horizontal/vertical table for a servo? Simple bracket and coupler?
3. Sourcing the rotary table/adapter plate/5" or 6" chuck on ebay... Any recommendations, potential stumbling blocks, etc? Don't need super high precision, and have found set ups for about $500+/-... ideas?
Thanks for the help. I look forward to accomplishing this little project.
Pete
www.sotmc.com
BTW: here is a link to the spec sheet on the driver from Logosol. http://www.logosolinc.com/download/ls-182.pdf
TIA
