Results 1 to 2 of 2
Thread: Help with cutting set up
    *Registered User*
    Jul 2003
    chandler, arizona
    If I have drawn a 2" x 2" square and I am using an 1/8" bit for cutting do I need to allow for the 1/8 offset from the bit . Jim Stidham
    Dec 2003
    You will have to allow for the cutter radius (1/16") somewhere, It all depends on the software you are using, with my post processor I introduce a G41 (left) or G42 (right), this way you program to the line and the G code offsets accordingly, of course the cutter diameter (offset) has to be known by the program to offset by the radius amount.
    Al
  1. Having trouble cutting aluminum sheet
    By fastturbovet in forum General Metalwork Discussion
    Last Post: 06-14-2005, 11:33 PM
  2. Cutting metal
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 02-20-2005, 12:14 AM
  3. CNC router deflection calcs and cutting loads?
    By Linus in forum DIY CNC Router Table Machines
    Last Post: 09-10-2004, 11:08 AM
  4. How to set up Tool Offset in MACH2?
    By High Seas in forum Mach Software (ArtSoft software)
    Last Post: 09-09-2004, 01:54 PM
  5. Do you account for climb cutting in G code?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 11-06-2003, 08:21 PM
