Results 1 to 11 of 11
Thread: Need some help with my router build
    Oct 2004
    Question Need some help with my router build
    Hi -
    Q-1 > Routing my wires
    What is the least expensive solution for routing all the wires?
    I have two steppers on my X-axis. I have 1 stepper on my Y-axis. And 1 stepper on my Z-axis. Then also have the power cord to my Z-axis for the router motor.
    Q-2 > Power supply
    I am having determining what size power supply I need?
    I have this board:
    http://www.stepmasternc.com/stepmasternc_009.htm
    This is the documentation to the controller board:
    http://www.stepmasternc.com/datasheet4axissop-1.pdf
    My Z-axis I have this motor:
    Astrosyn Mini Angle Stepper
    Type 23LM-C004-38
    6.0V/Phase
    1.2 A/Phase
    1.8 deg/step
    My X & Y I have three of these:
    http://cgi.ebay.com/BRAND-NEW-282-oz...QQcmdZViewItem
    https://home.comcast.net/~brenthub/p...2motordata.pdf
    Q-3 > Power supply out put
    The documentation says to use a volt metwer to determine output current in section 1.4 of the documentation. I am have trouble figuring out where I am to touch the leads for determining the output current.
    Current adjustment is made with the aid of voltometer at test points (TP X, TP Y, TP Z, and TP A). Be sure to make contact with COM probe at COM connection point at VBB INput.
    I have this board:
    Thanks -
    SS
    Please check out my CNC blog
    http://cncinside.com
    Mar 2003
    Shelby Twp, MI....USA
    1) I wouldn't recommend using the cheapest method possible, but that's just me.
    2)The data sheet says 2-6amps. This board appears to use the same chips as a Xylotex, and Xylotex says you shouldn't ever need more than 5amps for their drives. So 6 amps should be good, but more won't hurt you. It probably won't help either, just saying that if you have a 10 amp supply, it'll work fine as well.
    3) from the manual you linked to:
    The TPX, TPY, TPZ, and TPA are clearly labeled on the first page of the manual, as is the VBB common. Black lead to the VBB common (ground), and red to the TPZ, TPY, TPZ and TPA.
    Oct 2004
    Yeah and they are labeled on the actual board. But I have to be doing something wrong, because I just keep getting same reading regardless of where I put the red lead.
    And as for my other question - If I did not go the cheapest route, what is recommended method for the wires? These things are all over the place.
    Mar 2003
    You're turning the pots and the voltage doesn't change? VRX, VRY, VRZ, VRA?
    Oct 2004
    Quote Originally Posted by ger21 View Post
    Exactly. So figure I am doing something wrong. But with everything clearly marked - it looks like I am doing right thing by the directions given.
    Mar 2003
    You don't have the motors connected, do you?
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    if you watch ebay for power-one power supplies a good number of 24v supplies come up for sale cheap and they are good power supplies , ive got three one for each driver and they are nice
    Oct 2004
    No - not when doing this. It says not to connect them while doing it. Will try again on Sunday and let you know.
    THanks
    Oct 2005
    UK
    Quote Originally Posted by studysession View Post
    THanks
    Hi i have the same drivers out of interest what is the value you are getting on the test points?
    When i set mine up for the first time i'm not sure why but i was getting a value of 0 but turning the power on an off a couple of times resolved....
    Oct 2004
    My power supply is one from Radio shack and I get 15.XXXX volts. The XXXX is some value. But showing it is right over 15 volts.
    And it is the same no matter how I turn the POT. I will be able to try it again tomorrow (Sunday) and post wha thappens. Today I have to go out and deal with some family stuff.
    Mar 2003
    You are turning the correct pot, right? There are two sets of pots on that board. Not sure wjat the other set does.
    1. Newbie - To build or not to build Router/Plasma Table
      By dfranks in forum General Waterjet
      Last Post: 04-08-2011, 12:16 AM
    2. 1st cnc router build
      By ajl6549 in forum DIY CNC Router Table Machines
      Last Post: 11-02-2006, 12:47 PM
    3. Let's see If I can build this Router
      By Catapultsup in forum CNC Wood Router Project Log
      Last Post: 06-05-2005, 04:41 PM
    4. Build a CNC Router - FAQ
      By samualt in forum DIY CNC Router Table Machines
      Last Post: 04-13-2004, 09:55 AM
