Results 1 to 3 of 3
Thread: x-axis question
    Mar 2007
    Germany
    x-axis question
    Hi, I just found this forum and I see a lot of nice home made CNC routers here. I just got me a couple Vexta 1.8 deg/step stepper motors made by Oriental Motor Co. on eBay and I'm now thinking about my design.
    I want to build a cheap CNC router that can be used to mill wood and aluminum and can be used to create circuit boards. I have a Dremel type tool that I want to use.
    The two types of CNC designs I have seen are:
    1. The object to be milled is fixed in place and the tool moves
    2. The object moves back and forth and the tool only moves left/right and up/down
    Other than the extra space needed for the table when moving the object around, what are the pro's/con's to these different designs?
    Jan 2007
    UK
    You may like to make a start by reading through this thread Moving Table vs Moving Gantry; Dremel vs Router
    Good luck,
    John
    www.cnckitsandbits.co.uk
    Mar 2007
    Germany
    Thanks for the link, thats exactly what I was looking for. Another thing I was wondering about is whether to use my router or dremel is also coverd nicely in that thread. Thanks!
  1. 5 Axis Question
    By mark.browne in forum General Metal Working Machines
    Last Post: 06-29-2006, 08:59 AM
  2. Z axis question
    By Ric_A in forum Machines running Mach Software
    Last Post: 06-05-2006, 08:27 AM
  3. 5 axis question
    By turmite in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2005, 05:34 PM
  4. Question: 4th Axis
    By dwil in forum DIY CNC Router Table Machines
    Last Post: 10-10-2005, 12:58 PM
  5. 4'th axis question
    By 2muchstuff in forum Mechanical Calculations/Engineering Design
    Last Post: 08-09-2005, 09:34 AM
