Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: My first CNC Machine
    Jan 2007
    Ok, Here's a picture of my first CNC machine.
    And here's some specs.
    Work area is 15"X28"
    The motors are Xylotex 425oz/in
    I've got to upgrade the tool head and install the electronics
    but the major work is done.
    I built this for a cheap solution to drill holes in plastic and etch PCB's
    I did not follow any specs, I used a skill saw and hand drill. Thats why there is allot of screws. I just made it up as I went along. The worst part was getting everything to slide smooth.
    I know it looks kinda rough.
    But... What do you think ? will it work ?
    What should I change ? I used slide rails for the table. They use ball bearings.
    What do you think ? Don't be afraid of hurting my feelings, tell me what you think.
    Do you think it could mill small aluminium or brass with a new toolhead ?
    Thanks,
    -Mark
    deleteallusers@hotmail.com
    P.S. Do't be afraid of my username - I got free space at hotmail - they were afraid to delete it
    Here's the CNC machine. ( ua... As everyone knows it only takes about 3-4 days to make a machine like this, cause there very basic )
    Dec 2006
    Clw, FL
    Looks similar to rockford's design. Interesting way of getting more out of x axis. Does the table stay flat and level as it moves away?
    Have any videos of it cutting yet?
    Also is there a reason why z axis screw so long or is it just not trimmed yet?
    Looks good over all!
    Russ
    Jan 2007
    Thanks, I still got to trim the screws and hook it all up.
    I'm not sure how it's going to work yet.
    I'll post some video when I get it working.
    I'm going to do a second revision of the machine with enhanced bearing designs.
    I really want to do a maglev but I still to much of a novice
    to go there.
    Thanks for the feedback.
    Jan 2007
    UK
    Adding some screws higher up your gantry sides into the mdf will give the gantry more rigidity.
    Also if you could get another spindle clamp on there it would help.
    Other than that good job for a first machine.
    John
    www.cnckitsandbits.co.uk
    Jan 2007
    How tight/hard should it be to crank my motors by hand ? Also, where
    can I buy the hand cranks for the ends of the motors ?
    Everything seems really tight/stiff is that normal ? The motors are hard
    to turn by hand.
    Thanks,
    -Mark
    Jan 2007
    UK
    I presume you mean with power off? If yes then you should ideally be able to turn them quite easily between your thumb and one finger (turning via the screws). If it is difficult to turn them using your whole hand then you need to look for binding.
    As for buying hand wheels; hopefully some one your side of the pond will answer that.
    John
    Dec 2006
    Clw, FL
    I've seen some handwheels in grizzly catalog, but i'm pretty sure that enco and other suppliers carry them as well...
    Apr 2006
    I got my handles from mcmaster carr
    Jim
    Mar 2006
    NC, USA
    Ditto the spindle clamp.
    I made crank levers out of leftover plastic... picture a rectangular piece of 3/4" material 1"x4" drill hole in at one end to accept the shaft cut thru from the end to create a pinch type method of fastening to the shaft (screw tightener) and screw a knob of some kind on the other end. Of course mine is clamped to 1/2" ACME screw, this type arrangment might slip on slick motor shafts. However now that I've grown comfortable using the machine I rarely use the knobs.
    Regarding the difficulty in turning your screws... make sure your motor wires are not touching, in the right short ckt combination, cogging is much stronger. Perhaps you can undo the coupler and see if the screw turns easier.
    Curtis
    Jan 2007
    Thanks, everyone !
    Mar 2006
    NC, USA
    Pic of a homemade "knob".
    Feb 2007
    I'm not sure if its just me, but I am getting an error everytime i try clicking the link for your origional pic of the machine.
  • Page 1 of 2 12 LastLast
    1. G Code Variances from machine to machine?
      By Miguel Gonzalez in forum G-Code Programing
      Last Post: 03-28-2007, 04:31 AM
    2. Mach 2 on old machine = great machine
      By foamcutter in forum Machines running Mach Software
      Last Post: 12-16-2005, 01:11 PM
    3. Getting work(gcode) from machine a to machine b
      By strat in forum DIY CNC Router Table Machines
      Last Post: 07-07-2005, 03:13 PM
