Results 1 to 3 of 3
Thread: What wires to use?
    Oct 2004
    Question What wires to use?
    Hi -
    I am tryign to figure out what wires to use for the stepper motors. I know everyone has had to run longer wires from the controller board to the stepper motors.
    I went to home depot last night and seemed like the wires were to stiff to allow everything to move easily. Would like to know what everyone uses and where they get their wire from?
    Also what do you use to keep everything neat on the router so the wires do not bind up the machine or get in the way.
    Thanks -
    Please check out my CNC blog
    http://cncinside.com
    Jun 2006
    They recommend shielded wiring. I purchaced 6 conductor plus groung plus a shielding wrap on E-Bay for a reasonable price. Do a search for stepper wiring or something like that. I see some people use nonshielded cable. There are enough hurdles to have a cnc work properly. I wouldn't start by intentionally
    using parts that can easily create problems. I think I paid about $13 for 40'
    of shielded. This is my first cnc project and my table always works with no surprises. I've learned to trust it.
    Also I think it's 18 0r 20 ga......each conductor has 7 strands.
    Oct 2006
    Ebay for sure for wire..
    I got some good 2 conductor 16 gage that flexes nice and is shielded along with some 4 conductor 22 gage for the incoders that also flexes and is shielded. I run all of them down the same plastic chain guide and don't get any noise that I have seen... I still probably have 100+ ft of each after I was done.
    b/
  1. Best way to keep wires out of the way
    By CuttersCov in forum DIY CNC Router Table Machines
    Last Post: 11-02-2006, 09:40 PM
  2. Lead Wires?
    By aggie_67 in forum Stepper Motors and Drives
    Last Post: 06-05-2006, 10:02 PM
  3. DIY shielded wires
    By HogDog in forum General Electronics Discussion
    Last Post: 04-13-2006, 08:02 PM
  4. MDT flow wires to program cnc 3d
    By wjbzone in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 06-24-2003, 08:59 AM
