I make HDPE ones all the time. and using 1/4" bolts holes for adjustment. just state the sizes you need, or a drawing. you can message me.
Joe
I’m building my first CNC machine.
I’m placing a 5/8” steel rod through a ¾” plywood hole.
I need some kind of Adjustment block on the other end that has screws in it
so I can adjust the level of the rod. It would be a square block with 3
or 4 screws used to tighten and center the rod.
Here's an example.
http://www.cnczone.com/gallery/showp...to/824/cat/505
I dont want to build this part, I want to purchase it.
Does anyone know where I can get these kind of parts ?
Thanks,
Joe
well, I guess I should just make them.
Thanks anyway.
I think you're cutting the adjustment a bit tight. I used t-nuts on my adjusters so had about 1/2" around my pipes, but even without them I'd advise at least 3/8" around your pipe.
