Results 1 to 2 of 2
Thread: Possible to lengthen the y on Rockliff Router?
    Jan 2007
    U.S.A.
    I've just recently purchased the Rockcliff Router plans and plan to build one shortly. The 12X12 base model is a little small for what I'd like to use it for though. I'm curious if it would be possible to lengthen the Y axis on it? I'd definitely like to be able to modify this design shortly and have a 12"X 30"Y and 7"Z.
    I've looked at the re size sheet and think that it would be possible. I'm totally new at this but would like to give it a shot.
    Bryan
    Registered rockcliff's Avatar
    Dec 2006
    canada
    Quote Originally Posted by rcflybry View Post
    Bryan
    Hi Bryan
    I have just added a comercial version to the plan set using a fully supported bearing that can be streched to any lenght, can you send me your email to insure you have the additional drawings.
    Nick
    Rockcliff
    http://www.rockcliffmachine.com
  1. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 04:33 PM
  2. Surfcam PP for Isel router / Precix router
    By IvanTochev in forum Post Processor Files
    Last Post: 05-12-2004, 01:27 PM
