Results 1 to 2 of 2
Thread: Spindle not Running
    Feb 2007
    England
    Spindle not Running
    I am having trouble to get the spindle to run on a Colchester 600 with Fanuc 3T. I have entered the G codes to run the spindle on MDI but with no luck. Will not run on auto either, seems to not complete reading the line. X & Y axis are operating corectlly as is tool index. Drive motor has been checked electrically & is O.K.
    Any ideas????
    Registered jackson's Avatar
    Oct 2006
    im not sure on that machine but normally you use a M3 clockwise M4 c.clockwise M5 to stop, they need to be accompanied by an S like S1000 but you may need to find out if you need to call up a gear
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
  1. Running hot, really, really hot
    By imagineer in forum Stepper Motors and Drives
    Last Post: 01-18-2007, 09:51 AM
  2. Running a Fanuc spindle motor
    By Fudd in forum General Metal Working Machines
    Last Post: 11-11-2006, 10:21 AM
  3. Spindle quit running w/ c axix fault
    By TomCNC88 in forum Fadal
    Last Post: 07-28-2006, 11:07 AM
  4. Running an ATC
    By chrisw765 in forum Mach Software (ArtSoft software)
    Last Post: 11-08-2005, 08:20 PM
  5. Up and running!
    By maxxgraphix in forum DIY CNC Router Table Machines
    Last Post: 03-16-2005, 08:10 AM
