Results 1 to 8 of 8
Thread: Potential long axis roller...
    Registered Bowman's Avatar
    Sep 2004
    http://service.4casters.com/CatalogP...V/Default.aspx
    Just saw this and thought it might be workable if not this very thing something along the same lines maybe smaller. Not sure if anyone has gone this route before.
    Bowman
    Sep 2006
    took a look. Not that I know much but with a heavy gantry it might have possibility. Downside as shown it raises the gantry and doesnt constrain the gantry vertically.
    A dual setup set on its side with a diamond shaped rail makes sense to me. Smaller might be better.
    Jul 2005
    us
    These are a good choice for v-bearings:
    http://www.yi-tong.com/yi-tong/en/guide_wheels.htm
    Steve
    DO SOMETHING, EVEN IF IT'S WRONG!
    Oct 2006
    I don't see that as being very good. Probably not that great a bearing and the size of the V would be big needing a big square steel runner or something that would not have a lot of weld area since the V of the circle is pretty wide..
    The vgrove bearings with the double row ball bearing supports are better for this type a thing (and what my gantry uses to..)
    Becides 34 bucks each would add up quicker then the around 20 each for the larger v bearings.
    b.
    Jan 2007
    ireland
    are you for reall
    Sep 2004
    No dude I am for fakee
    Quote Originally Posted by gerry hanley View Post
    are you for reall
    Did I say everyone rush out and get these they are just what you need? Nope! Did I say this exact configuration was the ticket to success? Nope! Did I say hey all you folks building MDF routers or little PCB board cutters you need to use these big castors? Nope!
    All I was doing was posting something that looked interesting and could likely be used depending on what your trying to achieve for a long axis. See thats what forums do they exchange information what each individual does with it is up to them. If everyone was reluctant to post any ideas because people who have nothing to say such as yourself just ask if they are for "reall," wouldn't be much of a forum would it?
    I see you just made your 3rd post so your now 2 out of 3 on posts that have no relevance to anything other than your own opinion. To which you don't even begin to explain in reference to your cynical posts as to why you think what you do. Don't ask if someone is for real just for posting a thread, especially if you can't back up your statement with something useful or at least informative. Something tells me this concept eludes you however.
    Cheers,
    Bowman
    Mar 2004
    Iowa, USA
    It is too bad that some ideas get stuffed like this. Here is another site that has a v-grove wheel. I like these because they are metal and may hold up better in tougher situations. Keep thinking outside the box. Thats how we got CNC in the first place.
    http://www.acecasters.com/products/v-grooves.html
    RipperSoftware
    Jan 2007
    ireland
    now you are using your head
    1. Dual Drive on Long Axis?
      By rweatherly in forum JGRO Router Table Design
      Last Post: 11-30-2008, 02:21 AM
    2. Long Z axis machines
      By ynneb in forum DIY CNC Router Table Machines
      Last Post: 02-01-2007, 07:58 PM
    3. Choosing a drive screw and motor for a long axis?
      By CnoEvil in forum DIY CNC Router Table Machines
      Last Post: 01-08-2007, 06:40 PM
    4. Need 3-axis CNC vertical mill recommendations <$10k (Long post)
      By PCS74 in forum General Metal Working Machines
      Last Post: 03-08-2006, 01:38 AM
    5. Long X-axis methods: Rotate the nut?
      By OCNC in forum DIY CNC Router Table Machines
      Last Post: 11-23-2004, 05:13 PM
