Results 1 to 7 of 7
Thread: Linear slide is one good enough?
    Feb 2004
    Colorado
    Question Linear slide is one good enough?
    Found this ebay auction:
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=42899
    Do you guys think that just this one would work for the z axis or do you need two slides per axis?
    Jan 2004
    I think it would work fine. THK already have great strength, and that size should be a great platform. Course this is just my opinion, perhaps someone will chime in who has used something this size before.
    Stop talking about it and do it already!!!!!
    Feb 2004
    Colorado
    Well, I just bought it... Hope it works.
    Feb 2004
    Colorado
    Well spoke too soon... some one out bid me at the last second. Too bad...
    Gold Member
    Apr 2003
    Ohio, USA
    I am with Hobbiest, I have frequently wondered why not my self especially for non-commercial use.
    THK is precision stuff with zero play.
    Sorry you were outbid, been there done that
    Oct 2003
    Surrey, BC, Canada
    That would have been a good Z slide, I think the THK W series was designed to be used alone, or at least with just one rail. There is a service called Auction Sniper that you might want to try on eBay. http://www.auctionsniper.com It allows you to put in your highest bid, and how many seconds before the end of the auction you want to make the bid, then it bids for you right near the end of the auction. When I tried it, they gave me 6 free uses. If you try it, tell them steveage2 referred you and I'll get another free use Good luck next time.
    Steve
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    Nice looking slide - but might be a little short in the "throw" even for the zaxis. Remember you "give up" a portion of the length to the slide itself, so the net effective length is only the movement or just over 2 inches on that item. Same is true for x and y axis but there you "give up" even more to the gantry, router/spindle, etc.
    The thing I figured out (too late) was to try and standardize or get all the same model rail and slides, ie THK20xx, etc. That way I can join the rails to make a longer rail. Also, I could just get a pair of rails that has 1 slide per rail. You might find those rail sets with only 1 slide go for less than those with multiple slides. UH-OH let a little secret out
    Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    1. THK Slide pack FBW? Cheaper linear system?
      By InspirationTool in forum Linear and Rotary Motion
      Last Post: 05-25-2005, 06:21 PM
    2. T-Slot Linear Slide question
      By audball22386 in forum 80/20 TSLOTS and other Aluminum Framing Systems
      Last Post: 03-04-2005, 02:19 AM
    3. Simple linear slide design
      By CNCadmin in forum Linear and Rotary Motion
      Last Post: 01-19-2005, 04:55 PM
    4. linear slide rods for sale in the Netherlands
      By Tjippy in forum DIY CNC Router Table Machines
      Last Post: 12-06-2004, 02:46 PM
    5. Inexpensive Linear Slide Assemblies?
      By Homl in forum DIY CNC Router Table Machines
      Last Post: 06-03-2004, 02:05 AM
