Results 1 to 4 of 4
Thread: Alternative material for gantry parts
    Jan 2004
    By the way guys it might be worth noting that another material that could be used for making various cnc table parts is shown here:
    http://www.super-tech.com/root/rr.htm
    where what this guy did was make castings from composite polyurethane and aluminum powder. I spoke to him on the phone once. He said the original parts were made from wood and other easily worked materials. Then a silicon rubber mold is made from those parts.
    You can see from the pics that he made pretty nice looking parts that handled issues like bearings, bolt holes and right angles, and had the added feature of allowing him to make multiple units.
    I dont know what his source for polyurethane/aluminum is but I've done a fair amount of molding and could supply folks with a bunch of links if they were interested in more information.
    Owen
    Gold Member jgro's Avatar
    Jul 2003
    Re: Alternative material for gantry parts
    I would be interested in those links.
    jgro
    http://jgroshoppages.blogspot.com/
    Jan 2004
    http://www.synair.com/index.html
    http://www.rubbermoldcompounds.com/mold-making.htm
    http://www.smooth-on.com/
    http://www.gesilicones.com/silicones.../default2.html
    http://www.artstuf.com/
    http://www.alumilite.com/
    these guys have materials for something called cold casting which involves resin casting with metal powders -- it might be similar to what is used at super-tech:
    http://www.sculpt.com/technotes/COLDCAST.htm
    Dec 2003
    Las Vegas, NV
    Alumi-cast
    I'm planning on spin casting some parts that I routed out...after I make an inexpensive caster) thought about using this product. It's fast setting demold time around 2-3 minutes.
    Bill
  1. RFQ two Aluminum parts, cheap no rush
    By mike_r in forum Employment Opportunity
    Last Post: 04-28-2005, 11:14 PM
  2. Radius material setup
    By MikeA in forum Mastercam
    Last Post: 04-25-2005, 10:46 AM
  3. Boss8 parts - what are they worth?
    By fastturbovet in forum Bridgeport and Hardinge Mills
    Last Post: 04-08-2005, 07:47 AM
  4. Need some parts made and maybe more later.
    By dmgdesigns in forum Employment Opportunity
    Last Post: 10-24-2004, 02:00 PM
  5. Custom Car Parts
    By Gujustud in forum CNCzone Club House
    Last Post: 11-03-2003, 09:53 PM
