Here is a pic inside my box
UK cnc builders must check this out, a 700w router perfect for a diy cnc project, it is on special offer at B&Q £29.98 !!!
I bought mine before Xmas and thought I got a bargain for £46.99.
http://www.diy.com/diy/jsp/bq/produc...maxBullets=999
If you have problems with the link above type in 701w on the search button at www.diy.com - great web site address for a diy store. !!
It is really their version of a rotazip 700watt variable speed max 30,000 1/8 and 1/4 collet chuck.
Kit comes with plunge router, circle cutter, flexible drive, freehand clamp/handle (like a rotazip) and a really clever angle grinder/sander attachment.
It even has a light. !!!
Fantastic value for money, I have used it loads of times since I bought it and intend to use it for my cnc machine as it is ideal for fitting.
This is one of B&Q's own brand machines in the pro series, which you can register on line and get 3yr warranty !! How can you beat that.
Going to buy another one, as I will end up leaving this one in the CNC machine.
I bought one this morning.Quite a lot of goodys for very little money.The router seem quite robust as well.
Thanks for the tip!!!
Mark
http://www.weardalecnccarving.co.uk
