Results 1 to 7 of 7
Thread: Math help
    Oct 2006
    Math help
    Ya ya I know.. I'm a wimp..
    Just want to double check my numbers
    Using Mach 3...
    Have my 16 Teeth, 1" Pitch Diameter on my rack. Should be PI per turn 3.14159
    Through my 10:1 gear that would devide to 0.314159" per turn of the motor..
    So the question is what is the Steps per. And what should I use in the Step pulse 1-5US and Dir 0-5
    Kinda just guessed for my mill. on the steps per pulse and Dir entrys.. Have them set to 2..
    This is the motor with the 500 CPR (2000 ppr quad) incoder on it so that is what is throwing me.
    Mar 2003
    Shelby Twp, MI....USA
    2000/.314159 = 9549.3 steps per inch.
    Oct 2006
    Thanks Ger...
    I was getting to with in .004 per 1" movement with my "Guess" imput while playing last night moving the gantry around...hehe
    Z and Y were spot on..
    Got to get my table in.. Hopefully have some time to do that then I can cut something. Still have to get my limit switches in..
    Anywho..
    Registered drawbar's Avatar
    Apr 2004
    Doesn't 2000/.314159=6366.2 steps per inch?
    3000/.314159=9549.3 steps per inch.
    Brian
    Oct 2006
    Ok... 360 deg's / 3.14159 = 114.59165 deg's per inch.
    if we take 2000 steps per 360 degs we get 5.555555 deg's per step.
    Through the 10:1 I'm amplifying the 114.59165 degs per inch by 10 which would be
    1145.9165 degrees per inch.
    1145.9165 x 5.555555 = 6366.2021411575
    So the winner would be draw bar in my mind to.
    Although I've found that Mach likes something likes something just over 1000 steps per playing with th gantry moving ti with a dial indicator.
    I'll have to get the exact figure I stuck in there tonight. But as I recall it was less then 2000
    Pretty darn sure I have mach set to inches rather then mm's
    b.
    Oct 2006
    Actually the amount that seems right according to my dial caliper is ~1591.550535289375 in mach. Which is curiously 6366 / 4.. So I'm not sure what to make of that.
    Anywho.
    b.
    Mar 2003
    Quote Originally Posted by drawbar View Post
    Brian
    I'm going to blame that on my wireless keyboard that likes to drop keystrokes.
  • Posting Permissions
