Page 1 of 4 1234 LastLast
Results 1 to 12 of 37
Thread: Unipolar to Bipolar Stepper Conversion
    Mar 2006
    Recently I upgraded the controller on my 4 x 8 3 axis cnc machine, my stepper motors were unipolar on my old controller.
    But my new controller running Mach3 and Gecko 201 drivers required me to convert my unipolar to bipolar ( 4 vs 8 wires). No problem since my Vexta PK266-02A motors could run in both, after the conversion everything was working fine for about two weeks but now the x-axis is struggling and occasionally stalling.
    My questions are, by doing this conversion did I lose torque and since these were older (about eight years old) and smaller steppers to begin with is it possible that they are failing under the stress.
    Thanks,
    Tom
    Registered project5k's Avatar
    Sep 2006
    in my experience bipolar makes more torque than unipolar.. my first question would be is the drive current the same? and my second is are you running in full step, 1/2 or what? also, you need to know if you are running full step, are you running 1 coil on at a time, or 2?
    as for your existing motors.... a stepper will live forever, well almost, the bearings/bushings would be the first to fail, assuming that your not cooking them with too much current... so long as your not cooking them, and the bearings/bushings are good, then theres really nothing else that can fail.. its just a bunch of wires wound up, and some magnets attached to the shaft..... i suppose there is a remote possibility that the magnets have lost some of thier pull, but your conversion should have no effect on that one way or the other.... i would check your step mode, and how many coils your firing at a time... simplest fix to start with...
    Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
    Registered pminmo's Avatar
    Jun 2003
    St. Peters, Mo USA
    Practically you shouldn't have an issue running as unipolar for awhile then bipolar. Something has probably gone wrong. Most common place to start is your wiring, check your wiring connections that they are all tight, and that you didn't partially damage a wire. I assume you set the G201's to the correct current? Which is?
    Is it a 4, 6 or 8 wire motor?
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jul 2006
    Poland
    well
    if you have universal (8 wire) motors then you two ways of wireing them to bipolar the right way, and one the wrong :]
    you may put two coils of each winding in series for more torque on higher rpms or paralelly to get more on low speeds
    the other possibility is you connected just 4 wires, and left 4 dangling
    and running in this configuration with unchanged current limit will easly run you into problem with overheated rotor and partially demagnetization of it
    thus - poor torque
    Jul 2005
    us
    Quote Originally Posted by candle View Post
    well
    thus - poor torque
    Here's the way I understand possible 8 wire connections:
    Low end torque is the same for parallel or series.
    High end torque falls off faster for series connected because the inductance is much higher (4 times?) than parallel connected coils.
    I don't think connecting just one coil of each side is necessarily 'wrong'. It depends on the application...ie available current and voltage.
    Voltage and current values will be different for each case.
    Correct me if I'm wrong. Wouldn't be the first time.
    Steve
    DO SOMETHING, EVEN IF IT'S WRONG!
    Jul 2006
    Poland
    low end toruqe is lower for parrallel, but its more constant on higher rpm
    inductance is 2 times lower with parrallel, but there is close corelation between torque and inductance - the more inductance winding have, the more stall torque motor is able to produce
    im not telling that one coil is utterly wrong and the one who tryies should be hang, but it is a bit pointless (why not to start with smaller steppers at all?)
    Jul 2005
    us
    I stand by my original statements.
    If inductance in 1 coil = L
    Inductance in 2 coils in series = 2L
    Inductance in 2 coils parallel = L/2
    Therefore series inductance = 4 X parallel inductance.
    Simple circuits. Resistance is figured the same way.
    The low end torque is the same for series and parallel connected because when connected parallel you are allowed twice the current.
    Take a look at this data sheet for real numbers for real motors and you will see that the numbers are right. Just pick an 8 wire motor and follow across.
    Superior stepper motor data sheet
    Steve
    Jun 2003
    St. Peters, Mo USA
    Madclicker you are correct inductance will be 4X or 1/4th between the two wiring configurations. Torque is the same bipolar series or bipolar parallel as long as the current is correct for both wiring schemes. The speed curve will be much better for the bipolar parallel because of the lower inductance.
    Sep 2006
    um, im not nit picking, just making sure i understand, speed curve???? didnt you mean torque curve?
    Jul 2005
    us
    Yep, that would be nit picking. Technically it's called the "performance envelope".
    Steve
    Jun 2003
    St. Peters, Mo USA
    Speed vs. torque.......... Torque on one axis, speed on the other. I should have been more explicit........
    Sep 2006
    performance envelope huh??? well lets just get all technical then
  • Page 1 of 4 1234 LastLast
