Vibration isolators?
I been beating my brains trying come with the name of this item. It is a hard rubber cone shape/flat on both ends with bolt through it used for mounting just about anything. Usually 1/2 to maybe 2 inches tall.
thanks
bill
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
Rubber feet.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Well, I thought I'd would recognize the name if I heard it. vibration isolators and rubber feet does not ring a bell. It is something used very often under stationary small machines, small applicances, and some air compressorss. I plan to use these on light weight cnc machine (about 100 lbs or so). It is very common and usally its in black or gray. As I stated it is conical shape about 1 to 1 1/2 at the top with 1/2 foot print. I remmember seeing them in hardware stores.
thanks
bill
Rubber bumpers? See www.mcmaster.com page 3525
HayTay
Don't be the one that stands in the way of your success!
Conic vibration isolators?
MSC
Steve
haytay, thanks for the web address. these will work better than what I had in mind.
thanks
bill
I thought you said you needed a mount. Bumpers and feet are not mounts. gl with your quest.
Steve
Lord mounts??
